Found out Hyperlapses were stopping due to micro sd card
468 2 2023-12-2
djiuser_UAPzMrwJbYVy
Flight distance : 3072448 ft
The other day I posted that my hyperlapses were stopping mid hyperlapses and wanted to know what was causing it. Today I tried again and got an error message that basically said the micro sd was too slow to continue. I'm confused because this is the same sd card that I've used in the drone since release date and have done countless hyperlapses in the past with it. Does anyone know what may cause this or if there is a solution. Should I justt buy a new sd card. The drone in use is the original Mavic 3. I've had it since its initial release.
2023-12-2
Geebax
Try formatting the card afresh, file fragmentation can slow the write process quite noticeably.
2023-12-2
DJI Tony
Hi there.  SD card writing speed is related to the current number of files stored on the SD card and how the user uses it. The writing speed will generally be slow if the number of files is large. If the user, for example, occasionally deletes the files in the middle of the SD card this will lead to more file system fragmentation on the SD card, so the write speed will slow down. If the SD card writing speed is slow due to too much file fragmentation, try using a computer to format it. Have a great day ahead.
2023-12-2
