> Honestly that does not look nearly as bad as Avata 1 and looks very similar to what most other ducted drones will do.
I don't have Avata 1, so I can't compare the experience directly. I'm aware of the issue and have saw many videos about it showing it. I found it misleading how many youtubers are claiming that compared to Avata 1, with Avata 2 this has been fixed, or mostly fixed, at least to the point of it not being a problem at all anymore, which clearly isn't the case seeing how it almost caused a crash or two. I do have lot of experience flying manual so I was able to catch myself before hitting the ground, but if the bug happened a split second later, I'm not sure I would have had enough time to react.
> Wasnt there a warning for that when you turned on M mode.
I don't recall seeing any warnings about this particular bug, though to be honest I did gloss over the warnings, as they looked like all the same warnings I already saw in my DJI FPV drone that I've been flying in manual for last 3 years.
> Hi there, just double-confirm, may I know if the aircraft was in manual mode?
Yes, this is manual mode.
