"Low battery RTH" does not work in manual mode with RC3! possible??
407 22 5-4 12:05
zippomakerhotmail.com
Flight distance : 123182 ft
Hello
Today I was doing some testing, flying in manual mode with RC3 I waited for the battery to discharge to 20%, it gave me the "low battery warning" and told me to land but the RTH didn't start, I waited for it to discharge to 10 % and nothing to do... only message to land but the RTH has not started...
I landed in manual mode with the battery at 2%!!!!  does RTH only work for lost signals? or maybe it only works with motion controllers and not with RC3?
Is there a way to enable Low Battery RTH??
thanks
5-4 12:05
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We will coordinate this with our relevant team for further clarification. I will keep you posted. We appreciate your patience.
5-4 19:37
Dirty Bird
Flight distance : 41442379 ft
Odd.  Mine works fine.  Do you have RTH behavior set to Return to Home?  Not that it should matter for a low battery situation, but check that RTH isn't set to Hover or Land.
5-4 19:52
DAFlys
Min prompts me to cancel within X seconds and then does a return to home just fine with the RC3 controller.
5-4 23:14
djiuser_NJhtk5QHLbzK
Flight distance : 885823 ft
I noticed teh same behaviour when using manual mode. I actually prefer it this way. You can still acticate the RTH with the button on the RC3. Just curious why you would want hte RTH to ativate and pull you out of manual mode? kind of defeats the purpose of manual mode if you ask me
5-5 00:54
Dirty Bird Posted at 5-4 19:52
Hi, Yes RTH is set to Return to Home,  I tried to start the rth manually and it works but low battery rth no...
5-5 00:59
DAFlys Posted at 5-4 23:14
exactly... that's what I expected instead just warning messages...
5-5 01:00
djiuser_NJhtk5QHLbzK Posted at 5-5 00:54
you're right, I agree with you, in fact if you are following a line and it stops for the rth it could be boring, but in reality you have the possibility to cancel it... and in any case it is an anomalous behavior that doesn't work..
5-5 01:03
zippomakerhotmail.com Posted at 5-5 01:03
Hmm I am not so sure, I would think this is working as designed to be honest. Hopefully the DJI can reply and let us know
5-5 01:05
fichek
Flight distance : 1036263 ft
Croatia
People that say it works, are you flying in manual mode or just flying N/S mode with FPVRC3? Because I would personally also prefer it not to initiate RTH while in M mode.
User manual does mention this which makes me believe auto-RTH should not kick in in M mode: "In Manual mode, all flight assistance functions [...] are disabled"
5-5 02:16
DAFlys
zippomakerhotmail.com Posted at 5-5 01:00
Could it be you were too close to the homepoint?
5-5 03:04
Dirty Bird
zippomakerhotmail.com Posted at 5-5 00:59
Then as mentioned perhaps this is the way it is intended to function when flying in Manual Mode?  In N or S modes low battery does trigger RTH.
5-5 05:42
fichek Posted at 5-5 02:16
possible... where did you read this?
5-6 00:54
DAFlys Posted at 5-5 03:04
no, I was 300 meters away just to take the test
5-6 00:55
fichek
Croatia
zippomakerhotmail.com Posted at 5-6 00:54
Page 42 of the user manual.
5-6 01:28
DJI Paladin
Thank you for patiently waiting. Manual mode does not have low battery RTH function, if you need the low battery RTH function, please switch to normal or sport mode. We will surely gather this concern as suggestion and forward it to our relevant team for future consideration. We appreciate your understanding.
5-8 23:58
fichek
Croatia
DJI Paladin Posted at 5-8 23:58
Don't forward anything, it works as intended
5-9 02:53
Hi Paladin, yesterday I contacted DJI technical support via chat and this morning I did further tests as indicated by them. I did some tests with a friend of mine with another Avata2, so we tried both in manual and in sport mode, the RTH low battery with the use of the RC3 never works!!
We have the 1st low battery warning at 20% then the 2nd at 10% but the RTH procedure does not start...
in fact when the battery reached 5% the drone landed alone, distance 150m, (failsafe RTH set at 50 meters) we did a further test , by turning off the RC3 the RTH works, by turning off the glasses the RTH works, but the battery is low only warning, the RTH never starts... are you sure that it works with RC3 and it doesn't just work with the motion controller???
5-9 04:08
fichek Posted at 5-9 02:53
I think he didn't test with RC3 and Avata 2... I think he only tested with Avata 1....
5-9 04:14
I add to what I wrote before that we also did a test in sport mode... and the low battery RTH doesn't work... are you sure it works with RC3 and not just with motion controller?
5-9 04:16
fichek
Croatia
zippomakerhotmail.com Posted at 5-9 04:16
I just tried today, low battery RTH countdown appeared in both N and S modes on 2 separate batteries I tested.
5-11 10:01
I did some tests with a friend of mine with another Avata2, so we tried both in manual and in N/Sport mode, the RTH low battery with the use of the RC3 never works!!
With motion controller 2 works fine, battery at 25% "low battery RTH" starts and workd fine.
With DJI FPV RC3 no...
it doesn't work either in "N" or in "S" or in "MANUAL"
We have the 1st low battery warning at 25% but the RTH procedure does not start...
in fact when the battery reached 5% the drone auto landed alone,  (failsafe RTH set at 50 meters altitude) we did a further test , by turning off the RC3 the RTH works, by turning off the glasses the RTH works, by Motion controller works, but with RC2 only warnings, the RTH never starts...
5-18 13:09
fichek
Croatia
zippomakerhotmail.com Posted at 5-18 13:09
You're mixing up versions of controllers a bit, even in the video title and thumbnail
Anyway, I always cancel the low battery RTH when the countdown starts so I can't say with 100% certainty that it works beyond a warning, will try tomorrow.
5-18 14:37
