A fix for side light leaks.
522 27 5-6 04:34
DAFlys
If youre having light leaking from the side of your goggles, heres a fix for you.    Cut some 10mm thick foam as shown and slide into the sides,   you can even use the foam from the packaging of the goggles to make it.
Ive included some shots and a DXF file if you want to laser cut your own or you could just use scissors as it wont be seen when fitted.
Light Leak.zip
841.82 KB, Down times: 2
5-6 04:34
zappy49
Flight distance : 482260 ft
Good Idea Thanks
5-6 05:34
DAFlys
You’re very welcome.
5-6 05:44
DowntownRDB
Flight distance : 1722 ft
Excellent DIY fix for side light leak.
5-6 14:09
fichek
Flight distance : 1100308 ft
Croatia
Interesting solution. I've seen a few people wobble the rubber a bit after putting Goggles 3 on their face and they say that fixes the light leaks, did you maybe try that?
5-6 16:50
DAFlys
fichek Posted at 5-6 16:50
Yes I tries all sorts with the rubber but I still got very subtle light leaking from one side,
5-6 21:40
DAFlys
DowntownRDB Posted at 5-6 14:09
Cheers DT,  Its surprising how well this foam cuts with my laser too.
5-6 21:40
yogi053
Flight distance : 26104915 ft
Mine came with the foam which I jut cut down to fit inside the rubber curtain to afford further protecion. Any light leakage fixed by doing what fichek advises.
5-7 02:07
DAFlys
yogi053 Posted at 5-7 02:07
I must have a slightly deformed head then.
5-7 06:02
DowntownRDB
DAFlys Posted at 5-6 21:40
No doubt that made the DIY fix easy for you to do.
5-7 13:46
MAF178
Kuwait
Great idea Daflys .. thanks for sharing the cad file
5-7 14:11
DAFlys
MAF178 Posted at 5-7 14:11
No probs MAF178.
5-7 22:34
DAFlys
DowntownRDB Posted at 5-7 13:46
I must confess to cheating a little on this one,   to get the right curve I traced around the rubber and then scanner in the drawing and traced the cad over the top.
5-7 22:35
DowntownRDB
DAFlys Posted at 5-7 22:35
That's not cheating, that's just working smarter.
5-8 02:42
DAFlys
DowntownRDB Posted at 5-8 02:42
Its actually a bit of an odd curve more of an ellipse thats been cut than a arc.
5-8 23:28
IxToxicity
Flight distance : 39921 ft
What about light bleed from the top when using the extended forehead pad? it is horrible and gets so bright
5-11 12:48
DAFlys
IxToxicity Posted at 5-11 12:48
Ive not tried the pad,   didnt feel I needed it personally.
5-11 21:32
Montfrooij
Flight distance : 2560453 ft
Nice DIY job
5-21 10:26
DAFlys
thanks.  The laser cuts makes a nice job of cutting that foam,  as long as you put some tape on the back, to stop the light reflecting back from the mesh support in the machine.
5-21 23:57
Montfrooij
DAFlys Posted at 5-21 23:57
Nice.
Cutting would be hard otherwise (I struggled with that at least)
5-22 01:12
DAFlys
Montfrooij Posted at 5-22 01:12
Nice.
Accurate cuts in foam Id say was impossible without a laser.
5-22 02:10
Montfrooij
DAFlys Posted at 5-22 02:10
That was my conclusion too.
5-22 02:17
DAFlys
Montfrooij Posted at 5-22 02:17
It did help that I managed to get the shape right pretty quickly.
5-22 02:26
Montfrooij
DAFlys Posted at 5-22 02:26
Indeed that will have helped. Saving you from having to make multiple cuts to try and find the right size.
5-22 02:33
DAFlys
Montfrooij Posted at 5-22 02:33
I did do a test cut in cornflake box to see what the shape was like.  They are so useful.
5-22 04:43
Montfrooij
DAFlys Posted at 5-22 04:43
Now that is DIY
5-22 05:18
DAFlys
There was a TV show here for kids when I was growing up,  called Blue Peter,   there was a segment where they showed you how to make something with house hold waste,   like washing up liquid bottle into space ship or coat hanger into Christmas decoration,    cornflake boxes was a staple you'd have to keep to play along.       PS they now advertise washing up liquid that lasts so long that the kid is disappointed he cant make that rocket,    surely a joke for the oldies.
5-22 06:59
Montfrooij
DAFlys Posted at 5-22 06:59
Yeah, I remember that commercial. We had that too. It was a long time ago. Like 10-20yr ago.
5-23 09:28
