Serg SSA
![](https://forum44.djicdn.com/data/attachment/common/c8/common_2_usergroup_icon.png) Core User of DJI
Flight distance : 6542060 ft
Russia
It's hard to imagine that there will be vignetting with ND filters. It may be if you used VND because they consist of two polarized filters and there will be cross-shaped vignetting, but this is the case for everyone and you should not use them. In general, you should not use PL filters on a drone.
Color shift may only be noticeable on high density filters ND 256 and higher, but is usually easily corrected in the editor. Modern, even cheap filters use a good coating that does not cause noticeable color distortion. And if you then do color grading in the editor anyway, then the difference between cheap and expensive filters is not noticeable at all. But that's just my opinion)
I have a Freewell, but when I shoot a video, I first use the filter that I first took out of my bag and most often it’s a cheap Chinese one)
