DJI - Please confirm - MPP has camera been enhanced to allow 6...
1996 22 2017-10-11
GMG
Flight distance : 3632605 ft
An issue with the original Mavic Pro was the ability to film 4k 60fps.  I've seen a variety of comments about how the Platinum includes a change to the camera to allow for smooth 60fps, but I've not seen any confirmation of this fact by DJI.  Can someone from DJI please comment?Apologies if this has already been confirmed/debunked, but couldn't find anything when I searched.
2017-10-11
I will follow this thread, this rumor keeps popping up every now and then.
I don't know why DJI would not emphasize this more if it is true.
Maybe because that could be seen as a bug on the original MP but that is very negative thought.
2017-10-11
HereForTheBeer
Flight distance : 5381368 ft
unlikely given got same encoder. it would be very unfair to standard mavic if platium got 4k 60fps and standard doesn't given same encoder hardware and same speed and amount of ram..   not to say it couldnt get 4K 60, technically, both could do 4K 60fps if they both use HEVC and reduced the bitrate.
then other potential issue, i dont know how fast the microSD card system is inside the mavic pro, but im assuming probably around 20MB/Sec, and again, likely the plat has same system for that as well, which would make it hard for sustained 4K 60fps even with HEVC unless bit rate drops dramatically.
i dont know how to test how fast the microSD card reader/writter is inside the mavic but i do know from my own testings my peak speeds have never exceeded 20MB/sec and most of the time its aroudn 15MB/Sec. the card i use outside of the mavic pro in even a USB 2.0 writer/reader acheives atleast 50MB/sec and in usb 3.0 it runs at its rated speed for good amoutn of time, 75MB/Sec before slowing down to 50MB/Sec and staying there once its very hot.. so im thinking the SD card system mavic uses is not that fast..
2017-10-11
HereForTheBeer Posted at 2017-10-11 01:12
So we just have to wait for someone to really test this and see if the MPP is any better.
2017-10-11
HereForTheBeer
Montfrooij Posted at 2017-10-11 01:35
looks idenitical via offical spec sheet
2017-10-11
HereForTheBeer Posted at 2017-10-11 02:40
That I noticed too.
2017-10-11
DroneFlying
Flight distance : 10774613 ft
That would be a pretty big deal if it were true, but this is the first I'd heard of it. Out of curiosity, where were the comments that you saw about this?
2017-10-11
HereForTheBeer
ya i dont think it has 60fps 4K, that hardware is only now starting to get more accessible and i dont think dji would be that fast to put in such a new system without many hours of testing and abuse to ensure that it is ready and wont self destruct..
2017-10-11
HereForTheBeer Posted at 2017-10-11 03:14
I don't think so
2017-10-11
Mountaindrone
Flight distance : 27735479 ft
it's not in the specs
2017-10-11
Celsus
Flight distance : 196594 ft
An improved camera would be welcomed by  a lot of  owners judging by this survey. I hope DJI are making to do notes! https://forum.dji.com/thread-114137-1-1.html
2017-10-11
$gambino$
Flight distance : 1563980 ft
Supoosedly the 1080p was improved for smooth 60fps i guess tge regular mavic pro has a problem with 1080p 60fps ? Idk have not tried it. But did see rumours of betters 1080 60fps not 4k 60fps!
2017-10-11
Ex Machina
Flight distance : 1806362 ft
$gambino$ Posted at 2017-10-11 12:57
I saw that 1080/60, too, but I bet it's just an unfounded (or wishful thinking) rumor.
2017-10-11
Aardvark
Flight distance : 384432 ft
This is the best I've read regarding confirmation of a change1080P on the Platinum:-
https://forum.dji.com/forum.php? ... &fromuid=154551
2017-10-11
Lucas775
Flight distance : 50642090 ft
Spec doesn't show any difference.
2017-10-11
Aardvark Posted at 2017-10-11 16:42
https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=110991&pid=948734&fromuid=154551
That was the one I read also. Thanks
2017-10-11
Sir, we have not received any update of the Platinum camera for now. It is the same with Standard Mavic Pro.
2017-10-12
Jan Tomas
Ex Machina Posted at 2017-10-11 13:12
Hey there! My first post here so it doesn't let me create a new thread.
I've been researching about that 1080p 60fps rumour in the platinum for a while now.. it's weird that no one has made a real comparison with zooming to see the difference yet.
Actually, the last thing I found was this video that looks smooth as 60fps and doesn't have the typical moire. It also looks like his controller is the mavic one and he claims the fix has come with a software update.
DISCLAIMER: IT DOESN'T LET ME POST LINKS, so search for "DJI Mavic Pro 1080p 60FPS test 2" on youtube :/ The channel name is "Anton Chua"
Anybody can confirm or say if it's a hoax?
Thanks!
2017-10-14
dancopter
Flight distance : 17901030 ft
United Arab Emirates
Jan Tomas Posted at 2017-10-14 10:31
https://forum.dji.com/forum.php? ... &fromuid=545038
2017-10-15
Jan Tomas
dancopter Posted at 2017-10-15 03:20
https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=110991&pid=948734&fromuid=545038
Hi, thanks for the response. I did already read that post but it seems the video I mentioned is a regular Mavic Pro, bought in october with 1.04.00 firmware... NOT the platinum.
I posted a coment and he answered this: "Hi! I'm using the latest 1.04.00 firmware, supposedly released in September. I bought my Mavic in October so I don't have any reference for how it performed before this."
Does this mean the camera has been fixed in all new units? If that's the case, how can we make sure we don't buy something from an old stock and it has the camera fixed?
2017-10-16
Jan Tomas
He just confirmed it's a regular Mavic, NOT the platinum. So if someone with better eyes than me can confirm this vid is 60fps and it doesn't have moire, it seems the case is closed and all new Mavics will have the camera fixed
2017-10-17
Ex Machina
Jan Tomas Posted at 2017-10-17 12:05
I see moire on the fans. Sharpening makes the effect more obvious, so for content that doesn't have/need a lot of sharpening or have much in the way of straight lines, 1080p/60 can look ok.
2017-10-17
Jan Tomas
Ex Machina Posted at 2017-10-17 12:27
I can also see the moire in the fans, but I think that's the same yo would have at 1080p 30fps.
Nothing compared to what usually happens with the tree leaves in landscapes in all the other 1080p 60fps videos, where it's an absolute mess and is just incredibly unusable, like in this video:
2017-10-18
