file index mode ...
3162 13 2015-4-22
w1der
I am changing this to the "continous" mode ... But every time i turn the bird on again it has gone back to the "reset" option ... (using an iPad)
2015-4-22
HeadOn
Flight distance : 1903835 ft
Same problem here
2015-4-22
DJI-Autumn
You use an iOS device or Android?
2015-4-22
w1der
DJI-Autumn Posted at 2015-4-23 13:24
iOS
I am using both iPhone 5 and iPad air1
2015-4-23
DJI-Autumn
Did you shut the bird down in normal way? Usually you can save it unless you pull out the battery directly to shut it down.
I'll check it with my colleague again.
2015-4-23
jaron
+1 here.  Same problem on an IOS device.
2015-4-23
Farnk666
Flight distance : 1711394 ft
Can confirm - the setting does not stick!
Time for a new iOS app version with some bug fixes DJI!
2015-4-23
Fred D
Flight distance : 56184 ft
Same problem here, using an IOS device (iPad mini 2)
2015-4-23
w1der
DJI-Autumn Posted at 2015-4-23 19:29
Did you shut the bird down in normal way? Usually you can save it unless you pull out the battery d ...
I always use the "normal shutdown" method ... Press once then press and hold.
Have tried to change the setting about 3 or 4 times now ... On both devices without getting it to "stick".
2015-4-23
DJI-Autumn
w1der Posted at 2015-4-23 21:29
Have tried to chang ...
Try change another camera setting. Change the shooting mode to S or M mode from P mode, shut the bird off, restart, will it automatic switch to P mode?
2015-4-24
w1der
DJI-Autumn Posted at 2015-4-24 16:33
Try change another camera setting. Change the shooting mode to S or M mode from P mode, shut the bi ...
As long as the app is running I can turn the I1 off and on ... And it remembers the setting ...
How ever if I leave the I1 running and turning app on and off it wont remember the setting ... It returns to "reset".
Shooting mode S,M or P ... Now I am confused
I tried changing the ISO and shutter settings and restarted the app ... And they remained the same.
2015-4-24
DJI-Autumn
w1der Posted at 2015-4-24 18:52
Now I understand. If issue just happend when turn on and turn off the app, R&D already know the issue. Will be optimized later.
2015-4-29
w1der
DJI-Autumn Posted at 2015-4-30 09:58
Now I understand. If issue just happend when turn on and turn off the app, R&D already know the iss ...
Actually ... It seams as if the setting sticks ... Because the filenames is now in fact "continous" only the setting looks like it is still on reset ...
2015-4-30
Aguila
Flight distance : 28514 ft
w1der Posted at 2015-4-30 16:08
Actually ... It seams as if the setting sticks ... Because the filenames is now in fact "continous ...
I've had the same problem since I first got my P3P in January.  I have always used the latest firmware, and I'm now using 1.70060, the most up-to-date.  I still have the problem.  "Continuous" doesn't stick.  It reverts to "Reset."
2016-4-4
