I can't upgrade the firmware on Mavic Pro
1321 16 2017-12-7
retrogamermx
Mexico
I can't upgrade the firmware on Mavic Pro.
My AC is still on 01.03.04 version.
My RC is on 01.04.0100 version.
I tried a lot of times with DJI Assistant 2 and GO Apps, both also cannot.
error code:  0x020106
Please help, crying boy =..(
email:
2017-12-7
Jaovst
Hi. What is the battery percentage of the Mavic Pro Intelligent Battery when trying to update? If its under 50% then the update will not start.
2017-12-7
retrogamermx
Mexico
Jaovst Posted at 2017-12-7 09:31
battery rc and ac 100%
2017-12-7
retrogamermx
Mexico
No one? help!! =.(
2017-12-7
ChrisJP
Flight distance : 89888 ft
Japan
Have you read this?
https://forum.dji.com/thread-120182-1-1.html
According to the thread, you need to contact DJI, give them your email address registered with your account and ask them to enable a specific firmware.
Once done:
1.Log into your DJI account.
2.Upgrade the firmware to recommended version by DJI
3.Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to the latest one, it will be working.
2017-12-7
lannes
Flight distance : 4465 ft
You have the problem where you are 9 releases behind the current version  v01.04.0100 of the firmware,  if you are really on 01.03.04 version (14.02.17)
It's too big a leap to upgrade all 9releases in one go, I don't believe DJI code the firmware upgrade to allow you to do that.
As ChrisJP has suggested, you have to reach out to the DJI Forum moderators who will make available to you older releases  of the firmware so you can upgrade in smaller steps.
2017-12-7
retrogamermx
Mexico
ChrisJP Posted at 2017-12-7 14:11
Have you read this?
thank you very much, I really appreciate your help
2017-12-7
retrogamermx
Mexico
lannes Posted at 2017-12-7 14:46
thank you very much, sorry you know how to communicate with some forum moderator? or who are they?
2017-12-7
lannes
retrogamermx Posted at 2017-12-7 15:47
Just PM (personal message) DJI Susan, she will make firmware versions available on your account so you can upgrade, make sure to mention you are on version 01.03.04 as there maybe a few versions to upgrade into.
2017-12-7
Hi sir, I had forwarded a beta firmware to your account. Please refer to the steps ChrisJP mentioned in 5#. Make sure the battery is sufficient for the firmware update. See if it helps.
2017-12-7
Hi there, I got your PM, please connect the drone to DJI assistant 2, log in the same account that you provided, then the beta is on the list. Let me repeat the steps:
1. Log into your DJI account.
2. Upgrade the firmware V 01.03.0813.
3. Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to the latest version.
2017-12-7
retrogamermx
Mexico
DJI Thor Posted at 2017-12-7 22:13
Hi
I tried with the mentioned steps and it did not work for me = (
I attach some images
now I get the message Cannot take off and before it did not appear.  I'm sad =(
2017-12-8
retrogamermx
Mexico
I was able to solve the issue of can not take off, it is very difficult but it is flying again, but my AC is still on 01.03.04 version.
2017-12-8
fans88d8c4cf
How can I get the beta as well please?
2017-12-9
retrogamermx
Mexico
Any solution, can I keep flying like this?
2017-12-9
retrogamermx Posted at 2017-12-8 10:08
Hi
It would be better to keep the RC and drone in the consistency firmware. And now the firmware update has another error message, please try to update the firmware via another PC, if it doesn't help, please send it back, we will help to take care of it, thank you.  https://repair.dji.com/en/SelfRepair/Area
2017-12-10
lannes
retrogamermx Posted at 2017-12-9 13:14
Any solution, can I keep flying like this?[view_image]
Since you will most probably have to send it back for repair, have you tried updating from the DJI Go 4 app by hitting the "check for updates button" , make sure you have a strong wifi connection and that the tablet/phone battery is fully charged.
Can I ask one question, how come you are so far behind in the firmware upgrades ? It is a good idea to keep up to date with them as the later releases of the  DJI Go4 app may not work well with older AC firmware
2017-12-11
