Close call
684 11 2017-12-30
Nilesh-spark
Flight distance : 170919 ft
So, I went to a park, and confidently, as usual, launched my DJI spark. Immediately after launching, the drone flew away, at a very low altitude, but just kept going. The controller was responding, but not enough, and the drone flew on it's merry way. I ran after it, and eventually, managed to get control, and landed it quickly. I tried again, this time my hands shaking as I almost lost my drone. It went up, and finally, it was flying well, when my phone started beeping, and the drone lost control again. THis time it landed a little abruptly, but again safely. I did not want to chance it, and I put my drone away, and thought I would ask you clever people... what could have happened. PLease find the logs below:Loss of control immediately after takeoff    http://www.phantomhelp.com/logviewer/XGYSU96ESRRITYQ4EOFW/
Forced landing - not sure why - http://www.phantomhelp.com/logviewer/7WXZ4P5L27QP2EPBO4E3/
Thank you in advance.
Nilesh
2017-12-30
jksphoto
Flight distance : 114121 ft
You only had 5 satellites locked on at take off. I normally wait till at least 10.
2017-12-30
rimza
Flight distance : 3307 ft
Brunei
Home have not been established. Did the rear LED blinking green?
On the second flight you do have the home point established.
2017-12-30
Flight distance : 10186312 ft
First instance was caused by not enough gps to fly, you took off with just 5 sats, you need minimum of 11 to fly by gps, so Aircraft did not have proper gps lock. When this happens your Aircraft will not rise above 16 ft, it’s the failsafe height when flying from take off with not enough gps.
Second instance is not clear I had similar myself 3 days ago, if this happens again particularly over water, just something to remember by switching  from P mode to Sport and back again it will cancel forced landing.
2017-12-30
One thing I forgot to mention when your Aircraft  initiated Forced Landing your VPs was giving really bad readings, I wonder would there have been much condensation in the air causing your VPs to fog up and give incorrect readings ?
2017-12-30
m1n1s
Flight distance : 319915 ft
I had a simliar experience the other day , flying in cold grey conditions at about 100M up the Spark tried to land because of a VP error, flicked her in to sports mode and made my way back then selected p mode and landed, when i viewed the video later I could see i flew through some mist was wasn't visable from the ground but was enough to mess with the sensors on the spark.
2017-12-30
Nilesh-spark
hallmark007 Posted at 2017-12-30 11:02
That is a great tip. Thank you
2017-12-31
Nilesh-spark
hallmark007 Posted at 2017-12-30 11:19
No, it was a relatively clear day. But maybe it just needs to be cleaned. Could have been messed with the first flight
2017-12-31
Nilesh-spark
jksphoto Posted at 2017-12-30 06:28
Thank you. Good advice.
2017-12-31
Nilesh-spark
rimza Posted at 2017-12-30 07:01
It was too quick to notice anything. It just went off on it's own.
2017-12-31
Nilesh-spark
Cool, thanks. Lesson learnt!
2017-12-31
Paul Lee
Flight distance : 120623 ft
Always wait for the message that the Home Point has been updated... Even if it means hovering for a few minutes......
2017-12-31
