Mavic Air functions perfectly
2001 30 2018-2-3
MavicFit91
Flight distance : 573225 ft
When I bought the mavic pro in 2016 I read 100s of threads on how it did not fly correctly. Now I after buying the mavic air I am seeing it again. Before flying both for the first time, I took my time and set them up appropriately. Not one single problem, and I really hope DJI is not losing consumers because of users errors.
Thank you for continous great products DJI!
2018-2-3
A CW
Flight distance : 14416132 ft
Congrats - the Air looks like a great new addition to the line up
2018-2-3
M2Wair
Flight distance : 1192231 ft
Yes, mine works like a dream also, fabulous little drone, looking forward to using it when I'm on holiday or fishing.
2018-2-3
MavicFit91
Is not losing*
2018-2-3
eYeSkYeYe
Croatia
Where did you get from that DJI is losing consumers? With non-existant real competition right now, I believe DJI is actually expanding its user base like never before.
2018-2-3
MavicFit91
eYeSkYeYe Posted at 2018-2-3 11:17
It was a typo. I meant I really hope that they are not*
2018-2-3
eYeSkYeYe
Croatia
MavicFit91 Posted at 2018-2-3 11:19
They are not... I guess for every "lost" customer, they get at least 3 new.
I am extremely interested in small but capable drones and no one comes even close to DJI in that segment. Eagerly awaiting their new sub 250 grams one with ocusync or something even better. I don't care if it will be called Spark 2 or Mavic Nano or whatever, as long as I will be able to enjoy hobby freely like it used to be before annoying bureaucracy kicked in.
2018-2-3
Unfortunately those that work well, those users don’t always come back to tell their story, so we are left to decipher through those who have problems or just have not mastered correct and patient set up.  Good luck.
2018-2-3
windgate
I'm curious if you've had any experience flying the Mavic Air in higher population density areas with numerous Wifi routers that could cause interference. I too had no issues with my P3A, but hesitant to step up to purchase the Mavic Air with its Wifi communication between aircraft and RC.
2018-2-3
MavicFit91
Wingate I live in a pretty dense city/neighborhood and have had no Wi-Fi problems. To be honest in areas with a lot of interference it almost does as well as the mavic pro. Ad long as you don't try to fly to far ti fast, allow gps and wifi to get a solid connection before cruising off then the Wi-Fi is awesome. If you think about it there are telecommunications companies who can push Wi-Fi out 20 miles. Just an opinion, if it is the Wi-Fi scaring you away, I wouldn't let it.
2018-2-3
djiuser_8vwVSsovxPGK
I own MAVIC PRO, SPARK and now MAVIC AIR.
I've never had an issue until the Air.. Pulled it out of the box, updated firmware for all batteries... After going through the standard process, I tried to fly and had no satellites... Zero.
Talked to DJI support and they told me to connect to my computer using DJI Assitant 2 app. Factory reset later from PC and it was finally able to acquire satellites.
Suffice to say, the AIR flies just fine now... However it certainly wasn't as user-friendly as the other drones that I own from DJI.
Maybe it was a fluke... I'm just happy that DJI Support helped me out.
2018-2-3
Wachtberger
Flight distance : 261509 ft
Thank you for sharing your positive experience. This is very important too!
2018-2-3
fans45368d72
Flight distance : 787464 ft
I’m having some problems with my controller. I had it working perfectly yesterday. And today when I go to turn it on nothing happens no lights and it won’t charge. Any suggestions?
2018-2-3
MavicFit91
Fans46368d72 what port are you trying to charge it from ?
2018-2-3
TonyJ
Flight distance : 17100 ft
I got in a lot of flight time (for me) today with the Air and had no problems (other than the fact the RE goggles won't currently work with it ).
I am blown away by the obstacle avoidance system.  I watched a youtube that showed how much abuse the drone can take, so I tried my own, not-so-aggressively-destructive trial.  The main obstacles where I fly are mesquite trees and tree limbs.  In either forward or backwards mode, the drone really detects even the slightest number of branches and reacts.  I tried the full speed run directly at trees, branches and myself (not in sport mode!) and it never failed to halt 5-6 feet before the obstacle.  Very, very pleased.
And after trying the Spark and the Air while trying to diagnose the goggles issue, I really think the Air is much quieter than the Spark.
Very pleased, so far.
2018-2-3
Buzzyone
Flight distance : 4647913 ft
windgate Posted at 2018-2-3 12:42
I had a Spark and it would go 50 mtrs before losing RC or feed, that's in an urban area, the Air goes significantly beyond that (around 200Mtrs) in the same environment.
I will be flying it for a range test on a farm this week (weather was terrible this week) & with the spark I managed 750mtrs so I'm expecting a bit more than that, although spotting it without binoculars could be a challenge!
2018-2-3
Buzzyone
For the record mine works perfectly out of the box!
2018-2-3
windgate
Buzzyone Posted at 2018-2-3 16:24
Thank for the reply. 200 meters would certainly be a disappointment -- but seems to confirm my concern that Wifi interference is a problem for the Mavic Air.
2018-2-3
fans45368d72
MavicFit91 Posted at 2018-2-3 15:34
On the power adapter I’ve tried both of the USB ports. On the controller I connect it to the micro USB port on the left side of the controller
2018-2-3
MavicFit91
fans45368d72 Posted at 2018-2-3 17:03
Are you using the USB that came with the aircraft? Did you charge it fully before first use? Are you using android and apple? how long were you using it before it died?
2018-2-3
MavicFit91
windgate Posted at 2018-2-3 16:37
I have flown mine Significantly further than that. lets say a thousand meters while my wife watching with binoculars. You might have to move the antennas to get it but I have to do the same with the mavic pro.
2018-2-3
Tom_A
Flight distance : 899951 ft
I've flown a Spark and now my Mavic Air inside where I work. I was usually fairly close to the drone, but the place is lit up with wifi like a Christmas tree. It took me a long time to get up the courage to fly the Spark in the building. The only issue I had is that one of the rooms I flew in was a little too dark. The Spark drifted a bit as I flew it since it could not track the ground well and did not have GPS lock.
2018-2-3
fans45368d72
MavicFit91 Posted at 2018-2-3 17:18
Yes I am using the cable that came with the aircraft with the micro USB adapter. It was fully charged yesterday and when I went to go fly the remote would do nothing when I try to turn it on.  I’m using my iPhone X. The same device that I few just fine on yesterday. I used it yesterday just in my house to make sure it was working and then today it’s not working. It won’t turn on and it won’t charge. When I plug the remote in to charge it blinks 2-4 times and then goes black.
2018-2-4
fans45368d72
2018-2-4
fans45368d72
2018-2-4
rantanlan
Flight distance : 69698 ft
nice to see someone not complaining for a change ;) Guess it's just normal that you get biased by all the negative experiences since for the good ones there isn't the need to come to a forum and complain necessarily.
2018-2-4
MavicFit91
fans45368d72 Posted at 2018-2-4 00:51
Alright last questions for you, what is the longest that you have let it charged? is the usb plugged flesh against the dji adapter? I would recommend plugging into Dji assistant and refreshing firmware on your drone and RC.
2018-2-4
fans45368d72
MavicFit91 Posted at 2018-2-4 01:17
I have already updated hr firmware on the remote and the drone and did a very short test flight to confirm that it worked, and it did. I had the remote fully charged and then flew the drone for a few mins and then that night I put the batteries and remote back on the charger over night and in the morning the remote did work. ( batteries and drone charge and work just fine, just the remote is the problem). When I press the power button on the remote, nothing happens, no lights or anything. When I try to charge the remote, it lights up and looks like it is charging for 2-4 blinks and then the lights go off and the remote is completely black when I push the power button.
2018-2-4
Congratulations. Looks like a super cool bird!
2018-2-4
fansd1aedb51
Just got my Air yesterday! I love it! Flies perfectly out of the box and everything works fine! Many thanks DJI for a fantastic drone. I'm selling all my other drones apart from my small eachine.
2018-2-10
lovec1990
Flight distance : 36158 ft
Slovenia
MavicFit91 We are all diffrent some people buy a drone and just fly it then when things go bad they blame drone, but some of us read forums,Read manuals and watch youtube so we learn everything about a drone
2018-2-10
