Flight records not uploaded error at 3%
1525 31 2018-2-12
einstein-a-go-go
Flight distance : 277923 ft
Using the latest DJI GO 4 App for iOS, 4.2.6 and today I've noticed that I now get a failure, when tying to Sync Flight Records to Cloud, not had this issue before, never had an issues with flight logs uploading, it's also a bit odd, because the Cloud Symbol is located, which suggests they have ben uploaded, but distance covered here on the forum has not changed, and no logs are synced to UAV Data!
Tried via 4G Mobile, and two different ISPs via WiFi same issues ....
Coincidental updated to 4.2.6 yesterday, and this is the first time using it ?
The logs are as follows:-
[2018-02-12 10:09:50.832]Download Error ---- DJIFlightRecord_2018-01-22_[20-59-29].txt uncompress Error: -3
[2018-02-12 10:09:50.832]Download Error ---- DJIFlightRecord_2018-01-22_[20-59-29].txt saved file returns Error, retryTimeLeft:1
[2018-02-12 10:09:50.962]Download Error ---- DJIFlightRecord_2018-01-22_[20-59-29].txt uncompress Error: -3
[2018-02-12 10:09:50.962]Download Error ---- DJIFlightRecord_2018-01-22_[20-59-29].txt saved file returns Error, retryTimeLeft:0
[2018-02-12 10:09:50.963]flight record sync done ----
2018-2-12
einstein-a-go-go
it's odd because the Growth of Value just changed, but Sync still failed. and also Total Distance on phone is 73,252m, and in the forum 73254, but still missing 1 flight log.
2018-2-12
einstein-a-go-go
2018-2-12
Chicken_Butt
Flight distance : 175518 ft
Try signing out then sign back in.   See https://forum.dji.com/thread-134802-1-1.html.
2018-2-12
einstein-a-go-go
Chicken_Butt Posted at 2018-2-12 03:20
tried that, FAILED, same as before!
2018-2-12
CamiloMty
Flight distance : 2117995 ft
Mexico
Again same situation here, ios device, but Phantom 3 Pro. Have looong time with this issue, sometimes is ok, most fails.
2018-2-12
Oracle Miata
Flight distance : 3759829 ft
I also have this issue as of today.
2018-2-12
einstein-a-go-go
Oracle Miata Posted at 2018-2-12 08:20
not just me then... if versions are the same with app, or its serverside
2018-2-12
Greg Glasson
Flight distance : 284843 ft
Mine is failing to sync as well. Gets to 90% then has message "Sync failed. Retry". Have tried this on both iPad and iPhone 8 Plus, same result.
2018-2-12
einstein-a-go-go
Greg Glasson Posted at 2018-2-12 12:01
Yes, something weird going on here, because I'm managed a sync using Android App, and it's synced all my flights logs to Droid, and also synced to flights to DJI.
However, none of these new flights are available on Airdata UAV, which is a bit weird.
I just checked my iPad, which is on version 4.2.5, and it's partially synced, and fails at 89%.
So something is barfed with iOS.
2018-2-12
Oracle Miata
Yeah, latest version of app and IOS.  Used IPhone 6 and IPad mini 4.  Neither will sync.
2018-2-12
DJI Elektra
Hi, there. In your case, please provide us the DJI Account for further analysis. Thanks for your support.
2018-2-13
Greg Glasson
DJI Elektra Posted at 2018-2-13 00:05
Please check mine DJI Elektra.
2018-2-13
einstein-a-go-go
its the same as my forum account
2018-2-13
einstein-a-go-go
PM sent.
Andrew
2018-2-13
Oracle Miata
Bump, still an on going issue with IOS.
2018-2-13
BoMu
Flight distance : 587290 ft
Same issue here after IOS DJI Go 4 update to 4.2.6
2018-2-13
tonyh0905
Flight distance : 92441 ft
Same issue here. I have been using Go4 on a couple of different Android devices, clocking up time on a Spark, and Mavic Air, and the sync has worked without an issue. Today we bought an ipad, and set up Go4 on that. The set up went ok until I tried to sync my flight record, when I got the sync failed message.
I took the sparkRC out and flew with the ipad connected, and the flights were recorded properly. I tried sync'ing the flight record again after this and got the same message. I then logged on to Go4 with one of my Android devices, cleared the local cache, and sync'ed from there. The sync worked ok and included the flights I had on the ipad, so obviously the upload part of the sync had worked from the ipad.
I cleared the cache on the ipad and tried getting the the flights back, but still got the same sync failed.
Any clues?
2018-2-13
SkyBug2
Flight distance : 487566 ft
Same issue here... c’mon. Also having the same issues as Einstein. Total distance on the app and the forum are way off.
2018-2-13
bob_rush
Flight distance : 195866 ft
Same problem here in both DJIGo and DJIGo 4
2018-2-13
bob_rush
I might add that I tried it on both iPad and iPhone
2018-2-13
SkyBug2
Hers mine showing the difference in flight distance from go4 to forum distance
2018-2-13
einstein-a-go-go
glad its just NOT me.... i don't feel alone anymore!
2018-2-13
einstein-a-go-go
ALL WORKING AGAIN TODAY!
SYNC TO IPHONE COMPLETE, AND ALSO AIRCRAFT UAV working...
Back end issues ????
2018-2-14
airDD
Flight distance : 31089 ft
Start working again for  me too....
2018-2-14
Oracle Miata
SkyBug2 Posted at 2018-2-13 11:49
Hers mine showing the difference in flight distance from go4 to forum distance [view_image]
The forum distance is in meters and the app distance is in feet.  Hope that helps.
2018-2-14
fansd443533c
Flight distance : 56827 ft
Colombia
Same problem here.
2018-2-14
SkyBug2
Oracle Miata Posted at 2018-2-14 13:21
Ok, now that makes total sense. Thank you
2018-2-14
SkyBug2
2018-2-14
Oracle Miata
SkyBug2 Posted at 2018-2-14 15:24
Your welcome.
2018-2-14
DJI Diana
Flight distance : 2408 ft
Hi guys, we are sorry for the inconvenience and thank you for the feedback. This issue has been reported and fixed as confirmed by our experts from the headquarters. Please try syncing flight records again.
2018-2-14
DJI Elektra
Please follow Diana's advice, if the problem remains, please provide us the DJI Account and export the flight records in the path: /sdcard/DJI/dji.go.v4/FlightRecord/SyncResult Thanks for your support.
2018-2-28
