No Collision Avoidance on RTH
2286 11 2018-2-14
Hotwire
Flight distance : 10719 ft
I suspent this is and old topic however I couldn't find any references.
When on RTH, a notice says collision avoidance is off. This would seem to be when this feature was most required. Is this intended or can I switch this on for RTH?
2018-2-14
Lyons90
Flight distance : 164528 ft
it is intentional. before flying, make sure you RTH altitude is higher than any trees around
2018-2-14
SOUNDWAVE439
Flight distance : 115597 ft
Just make sure it is 30m+
2018-2-14
DJI Diana
Flight distance : 2408 ft
Hi Hotwire, Spark cannot avoid obstacles when RTH is triggered and the aircraft is further than 100m from the home point.  On the other hand, Spark can sense and actively attempt to avoid obstacles during RTH, provided that the lighting conditions are adequate enough for the sensing system and when the aircraft is less than 100m from home point. Meanwhile, there is no option to switch this on or off. You may also find this on page 15 of the manual. Here is the link --> https://dl.djicdn.com/downloads/ ... 0Manual%20V1.6-.pdf
2018-2-14
Hotwire
DJI Diana Posted at 2018-2-14 17:15
Hi Hotwire, Spark cannot avoid obstacles when RTH is triggered and the aircraft is further than 100m from the home point.  On the other hand, Spark can sense and actively attempt to avoid obstacles during RTH, provided that the lighting conditions are adequate enough for the sensing system and when the aircraft is less than 100m from home point. Meanwhile, there is no option to switch this on or off. You may also find this on page 15 of the manual. Here is the link --> https://dl.djicdn.com/downloads/Spark/Spark%20User%20Manual%20V1.6-.pdf
Thanks Diana, that's great and what I wanted to hear. I'm not sure there is a notice of the obstacle avoidance returning at the 100m mark. I will pay more attention next time.
What is the reason for the 100m perimeter?
2018-2-14
Hotwire
Lyons90 Posted at 2018-2-14 17:08
Not sure I understand what the scenario is that would make this desirable. This is also not the case for Mavic Air. If it can do this within 100m why not at any distance?
2018-2-14
Lyons90
Hotwire Posted at 2018-2-14 17:26
Didn't say it is desirable, I said it is intentional.
Top speed with obstacle avoidance on is 10km/h. Top speed on RTH without OA is 36km/h.
I would hedge a bet that OA is turned off purely for speed of return.
2018-2-14
Hotwire
Lyons90 Posted at 2018-2-14 18:07
So your suggestion implies Spark is short sighted. Certainly looks a little different to P4's and Mavic's Optical flow hardware.
Cheers
2018-2-14
Kloo Gee
Flight distance : 16783757 ft
Hotwire Posted at 2018-2-14 19:51
Cheers
Yes, it is a matter of speed.  DJI has decided if the Spark is reasonably close to you (less than 100m), it can come back to you at a slower speed where the obstacle avoidance system is able to function appropriately. However, they’ve made the decision if it is further away than that, then it will come back at a rate that is faster than the object avoidance system can function appropriately.
Here is a link to a video I made on the topic a while back.
DJI Spark - Return to Home Tutorial
p.s. I apologize about the technical problems near the end.
2018-2-14
Lyons90
Cheers
Yes. The Spark OA senses up to 5m and the Mavic up to 15m.
2018-2-14
Hotwire
Kloo Gee Posted at 2018-2-14 20:33
Excellent video Kloo Gee. Demoing all the RTH options is far more effective than the manual.
Cheers.
2018-2-15
DJI Diana
Hi everyone, thanks for sharing your insights in a video Kloo Gee.
2018-2-15
