yosephat
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 724570 ft
Indonesia
Dear DJI R&D,
I Also experienced this problem like sporadic video feed - occasional green image on screen and error message "Mobile device CPU fully loaded......".
I try to close all apps and uninstal some apps, but the result is the same.
I try to uninstal DJI GO4 and install it again, but the result is the same.
I try to Factory Reset my Ipad and install it again, but the result is still the same.
Then I try manual selecting chanel transmission and lowering bitrate to 4Mbps and it works fine.
so, I don't know the problem is in Apps or in my Ipad.
if problem is in my Ipad, please give me reason why the older DJI GO App is works fine and problem is apear after I do update.
okay, I believe its better for me (your customer) if you add some feature to detect CPU activity and display "Mobile device CPU fully loaded......" when in full load. But Why I still need to lowering bitrate to 4Mbps manualy? can you make some code to make it automatically lowering bit rate when CPU in fully load? or reduce some thing with heavy load? or do other smart things?
In my opinion, there is some bug or not run correctly in your DJI GO 4 Apps, especially on Block Code HD Transmission (Auto mode). Please tell your engineer to try before publishing.
if you don't believe me, please try it by your self.
SPECS:
Phantom 4 Pro (lastest Firmware Version).
DJI GO 4 Apps (the lastest version)
Ipad mini 4 (iOS 11.1)
Regards,
Yosephat. |
