Timelapse Issue with Osmo Mobile
6002 28 2018-3-4
Miltmanos
Hello Everyone,
For some reason I cannot record a timelapse longer than 20 seconds regardless of interval and duration settings with my Osmo Mobile 1.  It often records for just a few seconds and just stops.
This is happening on timelapse, hyperlapse, and motionlapse.  Using an iPhone 7Plus
What I’ve tried so far:
Updated to latest firmware 1.6.0.80
Removed the battery from the Osmo Mobile
Cleared the cache within the DJI GO app
Confirmed I have enough space on the iPhone
Charged battery for both devises to 100%
Tried each video resolution option
Uninstalled and reinstalled the DJI Go App
I have a feeling I’m doing something wrong and need help to identify it.
Milt
2018-3-4
It seems you have tried everything, could you please take a short video about the issue including the settings of Timelapse? We will forward to our engineers for further analysis, thank you very much.
2018-3-5
Does your screen also get dimmed after a couple of seconds?
2018-3-5
fansc566ac9a
Flight distance : 151276 ft
I'm having the same issue...
Using iPhone X running iOS 11.2.6
2018-3-5
Miltmanos
Thank you for the reply.  What is the easiest way to upload a video to the forum?
2018-3-5
Miltmanos
Here is the video taken using screen capture from my iPhone.  I tried it twice with two diff intervals and durations.
Thank you
2018-3-5
Miltmanos
Montfrooij Posted at 2018-3-5 05:04
Yes it does, i started tapping the screen to make sure it was not the cause.
2018-3-5
Miltmanos@gmail.com Posted at 2018-3-5 15:14
Thanks for that. It does not answer your question, but is is proof I am not alone in this dimming screen (see my latest question about dimming)
2018-3-5
Miltmanos@gmail.com Posted at 2018-3-5 15:13
Thank you
I can't view the video, is it possible you still have it on private?
2018-3-5
Thank you
PS, if you want Mindy to reply, it is best to click the small word Reply under her post instead of just starting an answer in the bottom part.
That way she gets a notification.
(all users get a notification if you reply to their answer by hitting 'reply' btw)
2018-3-5
Miltmanos
Montfrooij Posted at 2018-3-5 22:59
Thank you,
Milt
2018-3-6
Miltmanos
Montfrooij Posted at 2018-3-5 22:58
Fixed
Sorry and Thank you
Milt
2018-3-6
Yes, that is the way!
2018-3-6
Miltmanos@gmail.com Posted at 2018-3-6 05:47
Fixed
Sorry and Thank you
Milt
Yes, now I can see it.
That looks strange.
Almost like your internal memory is full or something.
2018-3-6
Miltmanos
Montfrooij Posted at 2018-3-6 05:50
That looks strange.
Yes, but Ihave almost 55GB of available memory on the iphone7 and deleted all videos and cleared the app of all videos as well.
2018-3-6
Miltmanos@gmail.com Posted at 2018-3-6 06:30
Strange.
I must say mine were not over 10s so far, so I have to try if it works for longer time with me.
2018-3-6
HiVoltageOne
Thank you
This is exactly what's happening with my phone as well...
It doesn't matter how long I set the Motionlapse for, it always stops about 10-15 seconds after it begins.
2018-3-6
HiVoltageOne Posted at 2018-3-6 07:37
I have to test, but it is dark now here in NL.
2018-3-6
I tried it today.
Got to 0:21 final video. About 5 minutes of recording timelapse.
Still no 'recording complete'.
Now I did get that notification when my end time was met.
(I first set it to 30 sec and got that notification after 30 sec)
So I see in your video you have set it to 10m, but somehow it does still end the recording.
That is strange.
What resolution are you on?
I am on 1080p
2018-3-8
Thank you
Thanks for the video, please reply to my post directly so that I can get the notification and reply to you as soon as possible, the issue has been forwarded to our engineers for further analysis, just to verify, you are running DJI Go V3.1.28 right?
2018-3-8
fansc566ac9a Posted at 2018-3-5 13:27
Do you have the exact same problem like Miltmanos shows in 6#? If yes, may I have your APP version and firmware version of your device? Thank you.
2018-3-8
HiVoltageOne
DJI Mindy Posted at 2018-3-8 02:18
Last night, just to test the hardware, I put a Pixel XL 2, (Android ver. 8.1.0; DJI Go ver. #3.1.28) into the gimbal...
Motionlapse ran just fine.
Seems to me that the problem is with the iPhone version of DJI Go or something in the current iOS, (running iOS ver. 11.2.6).
2018-3-8
HiVoltageOne Posted at 2018-3-8 06:57
Thanks for your thought and update, your opinion has been forwarded to our engineers for attention, I will keep you guys updated once there is any feedback.
2018-3-9
AidanKless
从视频中看是蓝牙断连导致延时摄影中断,建议客户换设备再次尝试。
2018-3-9
Miltmanos
AidanKless Posted at 2018-3-9 04:01
Thank you!  It looks like that worked.
2018-3-9
Miltmanos
Hello Everyone, it looks like the solution is to reset the bluetooth paring.  I clicked “forget device” in Bluetooth, opened the the app and paired the device within the app and its working now.  I hope this works for you also.  Please let us know.
Thank you to all for helping find a solution.
Milt
2018-3-9
jeffbake
Flight distance : 955587 ft
Miltmanos@gmail.com Posted at 2018-3-9 07:11
Milt
My Insta360 camera software notified me to reset the paring when I opened the app after the last iOS update. Bluetooth connectivity bugs where "fixed".
2018-3-9
Milt
The post in 24# is from our engineers, sorry for the Chinese version, it means the issue was caused by the interruption of Bluetooth, glad to know you figured out the problem. Hope you have a great time with it.
2018-3-23
fans01cb2af7
I am going to return my DJI Osmo mobile just for this reason. Why do you limit the timelapse?
2019-8-18
