The ideal storage temperature for Spark battery
2715 18 2018-3-16
Prelezli
Flight distance : 56188 ft
Turkey
There is Spark_Intelligent_Flight_Battery_Safety_Guidelines book.
In this book it is written that: "The ideal storage temperature is 22°C - 28°C".
In the chart that given in the picture, explains that if you store your battery in 25°C (with 40% charge) it will lose 4% capacity.
But  if you store your battery in 5°C (with 40% charge) it will lose 2% capacity.
So why Dji advice to store battery in 25°C? What is the root cause?
Detail Chart for storage
2018-3-16
Rustic17
Flight distance : 2733760 ft
Maybe because the chart is for standard LIPO batteries while the Spark's are Intelligent Batteries???   I don't know.
2018-3-16
Mr. Information
Philippines
hi let me give you this answer: The Ideal storage temperature of dji intelligent batteries would be 22C-28C. You can see that on the dji inteligent battery manual on the website.
2018-3-16
BeastMaster_101
Flight distance : 1082992 ft
Rustic17 Posted at 2018-3-16 09:00
Spark batteries are LIPO too
2018-3-16
Elettrone78
Flight distance : 2840512 ft
Every LIPO battery ideal storage is around 10°-15° celsius, it gives the least damage over time without having a frozen battery.
2018-3-16
Rustic17
Elettrone78 Posted at 2018-3-16 10:13
What is your source??? The OP had a chart...others have stated the DJI manual...what's yours???
2018-3-16
Rustic17
BeastMaster_101 Posted at 2018-3-16 10:11
I know the Spark's are LIPOs...I was just saying that since they are Intelligent, maybe they have something that reduces the capacity loss while storing at a higher temp than the OP's chart.
2018-3-16
Arcobaleno Reborn
Philippines
Your source? But DJi  has  stated their own specific  ideal storage on the manual at dji.com website. I do think we should follow the standard manual
2018-3-16
davidmartingraf
Good table and very useful information - this is what I've been looking for on these boards and now I found it, thanks!
2018-3-16
Prelezli
Turkey
You r wellcome. This chart is not only for LIPO and olso for Li-ion type batteries
2018-3-16
Prelezli
Turkey
Dji Representative please answer for this issue. Because in the Lithium base batteries chemistry reaction is increasing by temperature. This is not about with intelligent or not.
2018-3-16
Prelezli
Turkey
In Lipo batteries, moisture and liquid contact is very dangerous, which can cause to severe fire. Lipo fire is very dangerous. Lipo batteries stored in the refrigerator also have a high risk of getting moisture. Maybe this is why Dji company may have preferred the security  instead of more life for batteries.
2018-3-16
dji TO88
Flight distance : 4678 ft
Great info thanks for posting this.
2018-3-16
Elettrone78
Arcobaleno Reborn Posted at 2018-3-16 10:46
I once read an extensive LIPO essay written by some university in the USA, don't ask me to point you
to that article because I really don't remember, it was a few years ago.
The intelligent part in the batteries are just algorithms that optimize charge/discharge over time to deal as little damage as possible to the battery but being a chemical reaction battery time alone will irreversibly damage it in a way that it will eventually become unserviceable.
Hope this is good enough for you, cheers.
2018-3-17
Prelezli
Turkey
Thanks for usefull infos Elettrone78
2018-3-17
Prelezli
Turkey
Some battery experts explain that, when you store Dji battery in full charge, after 24 hours the intelligent battery automatically reduce the Charge level to %30. So Dji advice to store batteries in good ventilation room
2018-3-17
Elettrone78
Prelezli Posted at 2018-3-17 01:14
DJI intelligent batteries are programmed or can be programmed to start a slow discharge cycle down to roughly 65% over a couple of days producing a mild temeperature raise so unless the ambient air is scorching I doubt you’ll ever have any issue with that.
2018-3-17
Prelezli
Turkey
Elettronr78 thanks for this detail infos. Where did you see this infos?
My datas are stuffed informations, may not be fully accurate
2018-3-17
Elettrone78
I got 20+ intelligent batteries and I can tell you from experience but I’m sure you can find these infos on the manuals.
2018-3-17
