Mavic Air 4k recording Issues
4483 15 2018-3-29
Kim Aswani
Flight distance : 1574327 ft
I just sold my Spark and got myself my Mavic Air. I have been facing this issue with my recording in 4K. When I import the raw footage into my laptop and open it just to view the footage I seem to be getting it all in slow motion. I record in 4k with 30Fps. I noticed one more thing that the Icon where the SD card is there is a small yellow triangle which seems to say that the card has some issues, but all the recording is fine. Can someone please tell me what could be the issue. When I import it to my editing software, Filmora when I preview the file its seems ok, but when I expand the screen to fit the full screen the speed again is slow motion. I am a newbie and I really need some serious help.....please someone be kind enough to tell me what I am doing wrong. Do you think its the SD card that does not support 4K...or is it my laptop that does not support 4K. I have taken about 50 videos in the past 7 days but I have even tried to reduce the file size to 1080p at 30FPS, but the same issue. Can I reset the drone to factory default settings and start all over again.Guys...please help. I need a solution. I am really getting frustrated. I thank you in advance for a solution. Please Help.....Please Help....Please Help.
2018-3-29
i_seb
Flight distance : 363501 ft
Probably your SD Card doesn't have enough writing speed, you should use at least class 10 SD Card for 4k, you can check the raccomanded SD Card on the instruction or online.
2018-3-29
Kim Aswani
i_seb Posted at 2018-3-29 01:16
Thank you sir...You are too kind to reply. I will get a new card and try. Thanks again.
2018-3-29
i_seb
Kim Aswani Posted at 2018-3-29 01:18
Just make sure that's the real issue, check your SD Class before getting a new one ;)
2018-3-29
DJI Diana
Flight distance : 2408 ft
Hi Kim, I'm sorry to hear about the issue that you are experiencing. So the SD card that you used is not the original one? If so, as the floor 2# mentioned, please change an SD card to try it again. If there is any further issue, please feel free to let us know, we'll here for help. Thanks!
2018-3-29
Kim Aswani
sir do you think my laptop will support the 4k recording after I get a new SD card that can write as required by the Mavic...or do I need to upgrade my laptop as well. any suggestions on that if you are aware.
2018-3-29
What happens if you record to the internal memory?
2018-3-29
i_seb
What are the specs of your laptop?
You'll probably be able to watch the file in real speed, but for the editing we need to know the power of your laptop
2018-3-29
Stevom
Flight distance : 19245 ft
As above, this is a laptop issue and it not being able to process the video. I’ve had this problem and had to upgrade my PC in order to edit 4K video.
2018-3-29
Kim Aswani
DJI Diana Posted at 2018-3-29 01:28
Thanks for your reply. I just copied a few videos which were sluggish on my laptop and connected my projector and tried...all the videos are fine. No issues at all. its my laptop i feel. But i will still record on the internal memory first thing in the morning do a test flight and give you my feedback. I am so glad as i was worried thinking my aircraft had an issue.
2018-3-29
Kim Aswani
Stevom Posted at 2018-3-29 03:07
Thank you for your reply. Yes I guess so and i copied some videos to my hard disk and then connected it to my Smart Tv and also my projector and they are just playing fine. I was really worried. Thanks so i really just need to get a new laptop...My wife is going to throw me out of the house....does anyone have a spare room i will need one soon...new drone...new laptop...I will need to move soon.
2018-3-29
Robothamster
Flight distance : 51135 ft
Class 10 cards alone are not fast enough, you need to get a Sandisk Extreme 'U3' rated card with up to 100mbps write speed.
https://www.sandisk.co.uk/home/m ... treme-microsd-400gb
See here:
https://www.sdcard.org/developers/overview/speed_class/
I know this from experience, I had class 10 and really they were only good enough for 1080P recording, I had to get a U3 rated one to get rid of the warning message on the Air.
2018-3-29
Psilikoko
Hi ,i just bought Mavic air and i have an issue with footages. When i export the 4k/25p  footage to the laptop is seems like plays in slow motion and with bad movement like the print screen below. Same thing with 2.7K/25p. The footage is ok only in FHD: 1920×1080. I tried to record in internal storage too , but i have the same issue.
My SD card is  SanDisk microSDHC Extreme Pro 32GB
2018-6-26
North Idaho Guy
Flight distance : 2310082 ft
Mine (MA) does this and it appears to be associated with low/er ambient lighting levels....
2018-6-26
Psilikoko
I just solved my problem. As i said i import the footage in my laptop. I realized that my laptop does not support 4k & 2.7k videos. When i import the footage in my desktop which is by far faster and with a very good graphic card and 16 Ram , videos are perfect.
I feel a bit ....fool but maybe this can give some help to others with same issues
2018-6-26
Glad to know that you were able to identify the issue, normally if your computer could not produce higher resolution there's a possibility that the video will be forced to downgrade and it would depend on the capability of the computer or laptop.
2018-6-27
