Battery charge questions
1341 37 2018-4-4
nywrecker
Flight distance : 832421 ft
Why is it bad to keep the batteries fully charged for more than 10 days?To what level are they discharged automatically after 10 days?
How do you manually discharge a battery?
If a battery is at 50%, is it better to discharge and then recharge it, or straight charge?
2018-4-4
msinger
Flight distance : 228255 ft
There's no need to manually discharge batteries. If you set them aside and don't press the battery button, they will automatically discharge down to the storage level.
Check out this related thread from earlier today:
https://forum.dji.com/thread-142956-1-1.html
2018-4-4
dronist
You can set the discharge rate in the app. I set mine to 3 days and they will discharge after the 3rd day.
if I need to use them after that date then quick charge and am up and running so need to discharge to fully charge them.
You only need to fully discharge once every 6 month. Fly until 3%, stop your flight, let it cool and then you can charge them back.
I have 6 batteries for almost 18 months and so far none had any problems.
2018-4-4
nywrecker
dronist Posted at 2018-4-4 17:55
Where do you set the amount of days until the discharge?
What’s the actual need for the discharge?
2018-4-4
nywrecker Posted at 2018-4-4 19:18
Mavic Air intelligent battery will automatically discharge after 10 days storage. You don't need to set the auto-discharge time. For the discharge details, please refer to the screenshot below.
For your last question, you don't have to discharge the battery first then charge, just charge it to full directly. discharge.png
2018-4-4
Celsus
Flight distance : 196594 ft
I have set the minimum 3 days, however my preference is to take battery management into my own hands and leave the batteries at 50% after use if I won't be flying the drone in the next few days. I also ensure I fully recharge and discharge every 2-3 months. A short flight and the Mavic battery to USB charger adapter is a handy tool for this purpose.
2018-4-4
Wachtberger
Flight distance : 261509 ft
For Mavic Air there is no such setting.
2018-4-4
Hestia
Flight distance : 135381 ft
Wachtberger Posted at 2018-4-4 21:53
I was wondering why I did not find anything about it till now
2018-4-4
dronist
In the app under the battery page
2018-4-5
sky6105
Flight distance : 345653 ft
When the batteries go into self discharge do they give off much heat.
Do they need vented or can they stay in the hard case travel bag.
2018-4-5
DJI P5
Flight distance : 59610 ft
for mavic air you have no way to set the discharge timing, it fix to 10 days auto discharge
2018-4-6
dronist
DJI P5 Posted at 2018-4-6 17:06
The OP did NOT mention Mavic Air.
2018-4-6
dronist
sky6105 Posted at 2018-4-5 07:34
I never leave the battery in case. Always out on the shelf. You don't want a Kaboooom!
2018-4-6
LoSBoL
Flight distance : 666483 ft
dronist Posted at 2018-4-6 17:58
He didn't really need to, he designated the topic as Mavic Air...
2018-4-7
dronist
LoSBoL Posted at 2018-4-7 00:35
Yes he needs to because everything NOW under MAVIC is showing as MAVIC AIR, no more MAVIC PRO or MAVIC AIR.
Also on the thread top left ist says:
Home / MAVIC
2018-4-7
AG0N-Gary
Flight distance : 700846 ft
Reinforces what I said before.  The Air needs to have its own forum, not with the MP.  Way too confusing.
2018-4-7
LoSBoL
dronist Posted at 2018-4-7 18:17
That's not true, when opening a new thread, the topicstarter can designate the topic as Mavic Air, by choice. So if a topic is designated as 'Mavic Air', the topic is probably going to be about.... The Mavic Air.  But I agree with you, the forum is a mess, there at least should be an option to designate the topic as Mavic Pro, allong with better filter options so you can include or disclude certain topics.
It is however not a mess any user could or should work around or fix...
2018-4-7
LoSBoL
AG0N-Gary Posted at 2018-4-7 20:06
That's the problem, the Air HAS its own topic., the MP sadly doesn't... since DJI forget to add the topic when they created the Air topic.
The fix looks easy enough to implement, so what's taking so long.
2018-4-7
dronist
LoSBoL Posted at 2018-4-7 23:02
That is why in the thread's subject OP should mention MAVIC PRO or MAVIC AIR because the LAZY DJI programmer just replaced MAVIC PRO with MAVIC AIR.
2018-4-8
They will be fine in your case, and yes the will emit heat it’s normal, lipo bags which are pretty cheap are a very good option.
2018-4-8
sky6105
hallmark007 Posted at 2018-4-8 07:13
Thanks Hallmark didn't even think about the lipo bag.
2018-4-8
LoSBoL
dronist Posted at 2018-4-8 07:08
The programmer didn't replace anything, the Mavic Air category is new, he just was to lazy to also add a Mavic Pro category...
A topicstarter can choose in which category they post their thread, if they choose to put it in the Mavic Air category, what type of Mavic do you think the original poster is talking about in his thread?
So no, a topicstarter, talking about the Mavic Air,  who decides to put the thread in the Mavic Air category, does exactly what is expected, and doesn't need to fix DJI's mess, that's up to DJI...
So again, If a topic is marked Mavic Air, its probably about a... Mavic Air...
You can test it for yourself, select Mavic Air here at the top of the forum, look at the threads in the first page of threads, and find me a Mavic Pro topic. If your lucky you may find 1 or 2.
2018-4-8
dronist
LoSBoL Posted at 2018-4-8 08:44
Dude,
Yes they did. Before MAVIC AIRr it used to be MAVIC PRO for the past a year and a half MAVIC AIR was just released few month ago!
Second, how long have you been in the forum to know and or argue about what Category used or was there before? Third the OP did not complain or... So are you here to help others or keep going round and round?   Grow up dude!
2018-4-8
QuadKid
Flight distance : 482349 ft
Air Data is a great way to keep track of you battery usage and condition. It's free, although with limited usage.
2018-4-8
LoSBoL
dronist Posted at 2018-4-8 10:38
Dude,
Dude, You're flat-out lying.
It doesn't matter how long I visit this forum, Either way I've been here long enough to see the Mavic Air topic filter been created, It didn't substitute anything 'Dude'. There was no Mavic Pro topic filter. Here's a snapshot of before the Mavic Air filter was introduced so you can see for yourself.
2018-4-8
A CW
Flight distance : 14588274 ft
QuadKid Posted at 2018-4-8 10:49
That's good info to know as it seems the battery mAh capacity level no longer shows in the app
2018-4-8
Bluehook
Flight distance : 790814 ft
So, learning about my new MA and it's Lithium Polymer battery, I have become very aware of it's potential for temperamental behavior and even it's dangers.
Then, the other day, while working at my bench, I noticed that my Makita Screw Gun and my Makita Impact Driver both use Lithium-Ion batteries.  Now, I gotta tell you, for years, I have never paid any mind to these batteries.  I literally beat the living dog-sh*t out of them daily and never think twice about diminishing their performance or having them explode.
Other than the word -Lithium- do the Makita batteries have anything in common with the MA battery?  Should I be treating them differently?
2018-4-8
dronist
LoSBoL Posted at 2018-4-8 13:18
Dude, so you go to mommy and do some Photoshop and come back and paste it to make your point???
As I said before: "GROW UP DUDE"
The OP did not complain so you try to hijack his thread with your this or that or you'r flat=out lying, you are going to hell now...  BTW, How old are you?
2018-4-8
Brad Bilger
Flight distance : 14843274 ft
2018-4-8
LoSBoL
dronist Posted at 2018-4-8 17:00
Photoshop my ass, like I said, I've seen the Mavic Air filter being introduced. Funny thing about that internetz thing you should know 'Dude', everything gets archived: https://web.archive.org/web/20170911063420/https://forum.dji.com/forum-104-1.html
Your made up 'story' has been debunked and you know it.
A word of advise before you tell others to grow up, it doesn't get any credibility when you're laying on the floor kicking and screeming while lying thu your teeth acting like an ignorant, petulant child.
Now either shush, or cry us yet another river. It's up to you, 'Dude'
2018-4-8
dronist
LoSBoL Posted at 2018-4-8 21:26
Hahahaha, You are very GULLIBLE dude   Just pulling your legs and maybe your pants too.
As I said grow up, smell the coffee and mind your tongue!   this forum is read by teenagers too!
Move to another subject you so SERIOUSLY MATURE dude (Feel better now???).
2018-4-9
dronist
Just pulling his legs and went for it
2018-4-9
LoSBoL
dronist Posted at 2018-4-9 05:53
Well, you proved one thing, humor has no boundries. A bit of a weird masochistic sense of humor though, not many get enjoyment out of getting caught with their pants down.
2018-4-9
dronist
LoSBoL Posted at 2018-4-9 06:49
Well, you proved one thing, humor has no boundries. A bit of a weird masochistic sense of humor, not many get enjoyment out of getting caught with their pants down.
Dude HUMOR NEVER had and NEVER will have boundaries!
So chill out, go help some starving kids instead, maybe you will feel a lot better or maybe not!
Again, be careful what you write on the board, like (masochistic sense of humor) now kids are going to ask their mommy and daddy, what this MATURE GROWN UP dude mean (masochistic sense of humor)!
2018-4-9
LoSBoL
dronist Posted at 2018-4-9 07:00
You don't have kids now do ya?
Trust me, kids nowadays google things when they want to understand something, and then confront their parents. You'd love em, they will get you caught with your pants down on your ankels, sometimes even on a daily basis. Totally your cup of tea.
2018-4-9
dronist
LoSBoL Posted at 2018-4-9 07:42
I guess you know from experience
2018-4-9
LoSBoL
dronist Posted at 2018-4-9 07:47
Yes, a bundle of joy, which you will loose a lot of sleep over.
2018-4-9
dronist
LoSBoL Posted at 2018-4-9 08:58
Actually I am going to sleep with my socks on tonight, JUST for you
2018-4-9
