flying down the battery and falling drone
1983 34 2018-4-11
Jin_qng
Flight distance : 8468 ft
Vietnam
I use DJI from phantom2 + to phantom4. on April 11, 2018 when i use phamtom4 the distance from driver to airplane is 263m, the alarm is not connected. Wait a few minutes to try to reconnect and see no connection back. while still 53% battery life. After picking up the plane and checking the flight schedule error and i've officially lost it. I still fly normally. Would the firm give me an explanation of the above case and is there any direction for me to fix it?
2018-4-11
Hellsgate
Flight distance : 1991555 ft
Just to clarify have you lost your drone ?
Can you please upload your flight log and post a link to it here for our more experienced pilots to look at.
Its a little bit hard to understand what your issue really is for example are you only getting 263 mtrs distance and then loosing signal?
Can you please provide a little more detailed information.
I see your getting a battery error in your screen shot is this the problem you are refering too?
2018-4-11
Jin_qng
Vietnam
Hellsgate Posted at 2018-4-11 00:43
2018-4-11
Sorry, I can't understand what the problem is but if you share your recorded flight data it might make more sense.
Go to http://www.phantomhelp.com/LogViewer/Upload/
Follow the instructions there to upload your flight record from your phone or tablet.
Come back and post a link to the report it gives you.
2018-4-11
Hellsgate
Thats not exactly what i meant sorry what you need to do is find your flight logs on your device they can be found in the dji directory on your device once you find the log that relates to the error you are recieving please upload that log to this web site http://www.phantomhelp.com/logviewer/upload/
Once you have uploaded the flight log then you will need to post a link to that file in this thread.
If you like i can use a translalor into Vietnamese if this will help you
2018-4-11
Hellsgate
nếu điều này làm cho nó dễ dàng hơn cho bạn chỉ cho tôi biết tôi có thể giải thích quá trình cho bạn nếu bạn muốn.
2018-4-11
Siambuddhas Group
Flight distance : 116926 ft
The record will be in TXT files recorded on the handsets u used for the flight connection...upload the latest TXT files to the web link the bros shown as above........
2018-4-11
Hellsgate
Thats không chính xác những gì tôi có nghĩa là xin lỗi những gì bạn cần làm là tìm các bản ghi chuyến bay của bạn trên thiết bị của bạn chúng có thể được tìm thấy trong thư mục dji trên thiết bị của bạn một khi bạn tìm thấy đăng nhập có liên quan đến lỗi bạn đang nhận tải lên tải rằng đăng nhập này trang web http://www.phantomhelp.com/logviewer/upload/
Một khi bạn đã tải lên các bản ghi chuyến bay thì bạn sẽ cần phải đăng một liên kết đến tập tin đó trong chủ đề này.
Nếu bạn thích tôi có thể sử dụng một người phiên dịch sang tiếng Việt nếu điều này sẽ giúp bạn
2018-4-11
Jin_qng
Vietnam
Hellsgate Posted at 2018-4-11 02:11
http://www.phantomhelp.com/logviewer/MGSQI90BHSLFHZK22O9U/
2018-4-11
Jin_qng
Vietnam
Siambuddhas Group Posted at 2018-4-11 02:10
2018-4-11
Jin_qng
Vietnam
link day
2018-4-11
Mugrunty
Flight distance : 599449 ft
Wow, what the heck happened to cell #1?!  Everything looks fine up until around the 8 minite mark.  Then it instantly drops (within 1 measurement interval) about 0.3V.
2018-4-11
Jin_qng Posted at 2018-4-11 03:35
The battery is faulty.
At 8:07.1 the voltage in cell 1 drops significantly.
After 8:15 it falls below 3.3V which is the critical low battery level.
2018-4-11
Hellsgate
Pin bị lỗi.
Ở mức 8: 07.1 điện áp trong tế bào 1 giảm đáng kể.
Sau 8:15 nó rơi xuống dưới 3.3V, mức pin yếu tới hạn.
2018-4-11
RedHotPoker
Flight distance : 165105 ft
Try and deep cycle your flight pack...
That might fix it.
RedHotPoker
2018-4-11
Jin_qng
Vietnam
RedHotPoker Posted at 2018-4-11 13:01
That might fix it.
Where is the broken plane that try
2018-4-11
Jin_qng
Vietnam
Hellsgate Posted at 2018-4-11 12:12
Pin bị lỗi.
How to make battery still report 53%, and do not go to error on the screen so when not connected and my plane died.
2018-4-11
Jin_qng
Vietnam
Labroides Posted at 2018-4-11 11:23
2018-4-11
Jin_qng
Vietnam
done
2018-4-11
RedHotPoker
Send it in for tech. evaluation and estimate...
I would fix it, if not a warranty issue.
RedHotPoker
2018-4-11
RedHotPoker
Jin_qng Posted at 2018-4-11 16:19
Sorry, my misunderstanding.
Never mind, ok carry on.
RedHotPoker
2018-4-11
Jin_qng
Vietnam
RedHotPoker Posted at 2018-4-11 19:13
I am in Vietnam and do not know how to fix this to show your work. Can help me find repair in Vietnam Thank you!
2018-4-11
Flight distance : 2354357 ft
I would await for a DJI Moderrator or Admin to show and they will advise on your next course but they will probably tell you to go to here and open a ticket https://www.dji.com/support
Having just googled DJI Vietnam, it came up with these??? http://flycampro.vn/
2018-4-11
Jin_qng
Vietnam
admin and mod give you little comment
2018-4-11
Hellsgate
nếu bạn đi đến phần hỗ trợ trong ứng dụng dji đi, bạn có thể liên hệ với hỗ trợ họ sẽ gửi cho bạn hướng dẫn về và làm thế nào để gửi drone để sửa chữa
2018-4-11
Hellsgate
Ouch that looks like it was a nasty fall
2018-4-11
KedDK
Flight distance : 1133038 ft
Wondering what was the conditions on this last and latest flights, can it have been exposed to moisture or condensing from moving between cold and warm places?
What makes me wonder is the way the others cells raise their voltage when cell1 go low like something gets shorted out on the board.
2018-4-12
Jin_qng
Vietnam
Under normal conditions, not with the water or moist environment, I also do not why? And I want to find out more about this issue. I guarantee my environment is very stable, I am using many devices like this.
2018-4-12
RedHotPoker
Jin_qng Posted at 2018-4-11 19:22
A forum moderator, should be able to help you through this excrutiating repair process.
RedHotPoker
2018-4-12
Jin_qng
Vietnam
can not see anyone
2018-4-15
Jin_qng
Vietnam
2018-4-15
Jin_qng
Vietnam
2018-4-15
Jin_qng
Vietnam
2018-4-15
Sorry for the late response. If the drone is still in warranty period, we will arrange data analysis to check the exact status. You can contact support@dji.com to start a case.
Alternatively, contact the local dealers and ask them report in dealer system: https://www.dji.com/where-to-buy
2018-4-15
Jin_qng
Vietnam
The aircraft has run out of warranty but I find this error to be ridiculous. No battery error at first. and this error is very dangerous. The machine has broken the martial and gimble break expecting admin to assist me to fix it. thanks admin. I rest in case like me, just look at the plane only
2018-4-16
