coreynach
Flight distance : 208589 ft
Chances are it really isn't level. Question for you... Have you done the IMU calibration (on a perfectly level surface) followed by a full gimbal calibration (again, on the same level surface)?
While DJI certainly does calibrate this stuff before shipping, IMUs (which stands for Inertial Measurement Units) are sensitive to jostling. If they move slightly out of place, or get jostled, their reading may be slightly off... All of you gimbals settings will be affect by the IMU's settings. Find a perfectly level surface, Calibrate your IMU first, and then calibrate the gimbal again.
If you still get times where it seems the horizon levelness is drifting, than this could be more an issue with a "follow" setting in the gimbal... |
