P3
2079 16 2015-5-26
Nguyễn Thắng
I used return to home feature.
2015-5-26
nickmedici
Flight distance : 88287 ft
Sorry to hear. I assume battery percentage was in good shape? And your fingers were not on the sticks?
2015-5-26
Nguyễn Thắng
kjghdvxbn sygfdgfds
2015-5-26
mackie1604
Nguyễn Thắng Posted at 2015-5-27 13:11
Thanks. The battery was definitely more than 50%. I might had thumbs but they should not interfere r ...
If you pull both to inner corners you can shut it down in air I thought.......
Maybe the battery was loose or not clicked in fully.  Sorry for your loss, call them for sure and file a claim.  They can look at the black box data and see what happened.
2015-5-26
lightpanther
mackie1604 Posted at 2015-5-27 13:19
Maybe the battery  ...
But if the lights were still on, then the battery had to be working.
2015-5-26
DJI-Autumn
From your description. I assume it didn't shutdown with CSC, you can check your operation in flight record playback, and if possible sycn it to cloud thanks.
Pls contact NA support, we will help you.
2015-5-26
mackie1604
lightpanther Posted at 2015-5-27 13:48
Agreed.  Maybe the GPS altitude was slightly off so it assumed it was on the ground and shutdown power?
2015-5-26
sploodge
Flight distance : 809350 ft
Please post your flight record for us to see what was happening when it fell.
Remember to buy extra propellers and one or two spare batteries to keep you flying
2015-5-26
Daninho
Flight distance : 70203 ft
Which FW you used?
2015-5-27
jon.jongodfrey
mackie1604 Posted at 2015-5-27 13:55
Agreed.  Maybe the GPS altitude was slightly off so it assumed it was on the ground and shutdown po ...
No I don't think it works like that... GPS altitude is not accurate enough.  I read somewhere on here that in drops at a controlled rate until it can't drop any further then shuts down the motors.  It controls (or should control) rate of decent but only uses sensors and GPS to tell it in can't drop any further so it must have landed.
2015-5-27
fiskld
I am sure that somewhere in the decent the sonar function kicks in to give it a reference to the ground. I don't know that for sure but it seems like it would be programmed to use that function.
2015-5-27
droneflyers.com
Flight distance : 60709 ft
Thumbs can definitely shut down the motors in mid-air.
The logs should show exactly what happened in this case.
2015-5-27
mswall
Flight distance : 39695 ft
At 50% battery why did you initiate RTH?
2015-5-27
lightpanther
mswall@mac.com Posted at 2015-5-27 22:03
IMO, It should not be possible to shut down the motors in midair without a big flashing warning you have to pro-actively click on at least once, if not twice, on the screen.
2015-5-27
Nguyễn Thắng
It was my first time using RTH. I wanted to test the feature.
2015-5-27
Nguyễn Thắng
vdsbaermy yaregreaghqeahd
2015-5-27
Nguyễn Thắng
DJI-Autumn Posted at 2015-5-27 13:49
From your description. I assume it didn't shutdown with CSC, you can check your operation in flight  ...
Hi -- Could you gfds jsw
2015-5-27
