N3 + LB2 + X5 (error in X5)
1869 13 2018-5-8
Bruno Soares
I have N3 + LB2 + X5, I have all the X5 commands on the screen, but I can not get the X5 video image (FPV) on my tablet, they could help me, because I have an urgent need to use the X5.
2018-5-8
Bruno Soares
2018-5-8
Bruno Soares
2018-5-8
Bruno Soares
2018-5-8
Bruno Soares
2018-5-8
WiSi-Testpilot
Select EXT in the HD screen. You may play with the settings. If it does not work, please show the screenshot.
Best regards,
Wilhelm
2018-5-9
Bruno Soares
WiSi-Testpilot Posted at 2018-5-9 13:56
Best regards,
Wilhelm
I've tried all the settings and still it still has a problem.
2018-5-10
WiSi-Testpilot
Try LB 10% EXT 90% and App Output mode LB, see my screenshot. I think there are some bugs. For example, it does not work with EXT 100 %, but it should.
For DJI, the setup is: N3, LB2 with channel extension, Z3, Crystalsky, all current firmware.
Best regards,
Wilhelm
2018-5-10
DJI Elektra
Hi, there. In your situation, I would recommend you update your camera and the drone again. Please keep us updated, thanks.
2018-5-11
Bruno Soares
DJI Elektra Posted at 2018-5-11 02:31
But everything is up to date, do you recommend updating which equipment?
2018-5-11
WiSi-Testpilot
@Elektra, thank you for your response. All my devices have current firmware. Only using the settings shown above the Z3 works. Otherwise the screen is black, as shown by Bruno. It should also work with 100% EXT, but it does not. Therefore I thing there is a bug.
Best regards,
Wilhelm
2018-5-11
Regijean
Hi, unfortunately it looks like you have inspire firmware (1.11.1.5) on your X5 you need m600 (1.10.01.4) and im not sure how you can roll back. Good luck
Firmware
Inspire 1 Pro Firmware v1.11.1.50    2017-07-10
MATRICE600_V01.10.01.40
2018-5-13
Bruno Soares
Does anyone know how I can downgrade the x5 firmware from 1.11.1.5 to 1.10.01.4?
2018-5-28
Appleyard
I'm having the same problem. Anyone found a way?
2019-8-24
