Cannot connect RC to Spark
1942 11 2018-6-13
Starshark
Ukraine
Hi All. Sorry my English.
Anyway not connect  rc (model:gl100a c2 ) and spark (model:MM1A). Any metod: watch video, read thread on this foforum, reset rc and spark, connect with assistant.... fail always.
Connect DJI Go with RC - succesfull
Connect DJI Go with Spark - succesful
Connect RC with Spark - unsuccesful permanently.
Help me please.
2018-6-13
Hello, Sorry for the inconvenience. May I know what is the current firmware version of your Spark and remote controller? What is the color of the aircraft's rear indicator light? Please provide the complete details on how did you link your remote controller to your aircraft and if you receive an error message. Thank you.
2018-6-13
Starshark
Ukraine
How do I check firmare version on both RC and Spark?
Anyway, I''ve tried to connect them both using android app (DJI GO 4) and without with same result - when I turn spark into "binding mode" by holding power button for more than 3 seconds (front lights are blinking red, rear lights are blinking yellow faster) and then turn RC into same binding mode (either via app or holding FN+Pause+right low button for 3 seconds or so) - RC starts beeping, there's blinking red LED on RC that indicates that it's in binding mode. Then I place both spark and controller on top of eachother, so there's definitely less than 20sm between them. They're just beeping for minute or so and nothing happens. I've tried it multiple times with same result, so either I do something wrong or there's somethign wrong with controller or spark.
Previously I\ve tried to fly on it via android app - it worked fine, controls aren't comfortable enough though so I desided to buy RC - and this is where I stuck.
2018-6-13
Starshark Posted at 2018-6-13 02:34
Hello, you can check the firmware version on the app.
1. Open the DJI Go 4 app (make sure to power on both aircraft and remote controller).
2. Enter camera view
3. Tap the 3 dots icon on the upper right.
4. Go to general settings and look for "about".
We need to refresh the wifi of your Spark. To reset, hold the battery down for 9 seconds until you hear the aircraft beep three times. The next step is linking the remote controller to the aircraft. Press the Pause, Fn, and C1 buttons at the same time. Once the controller starts beeping, release these buttons. With Spark powered on, press and hold the battery power button for 3 seconds. When you hear Spark beep, release this button. Make sure both aircraft and remote controller is fully charge.
2018-6-13
Starshark
Ukraine
I checked firmware on Spark and RC using dji go 4 and hold "3 dashes" menu.
rc: 01.00.0400 (rc)
spark: 01.00.0900 (ac)
2018-6-13
S-e-ven
Flight distance : 5922034 ft
You tries with resetting the RC by holding the power button  of the switched on RC for 9 secs?
And the same for the Spark? Total reset, 9 secs, 3 beeps?
2018-6-13
Starshark
Ukraine
I have tried to reset multiplie times.
2018-6-13
Starshark
Ukraine
I done this. Success pairing rc and drone after downgrade rc firmware to 01.00.0300
2018-6-13
S.J
Flight distance : 322454 ft
Kuwait
Starshark Posted at 2018-6-13 05:12
better to update rc firmware.
2018-6-13
Starshark
Ukraine
And repeat all my unsucess story?
2018-6-14
jmb63
Flight distance : 7009439 ft
Maybe I am reading your first post and the steps you have taken incorrectly but you can't have the phone/device AND the RC connected to the spark at the same time. Re-check your procedures but if you have DJI Go connected to the spark, then the RC (remote control) will not connect!  Connect the RC to the Spark then start the DJI Go app.
2018-6-14
djiuser_qly0EYrHioX1
Hi I have a brand new Spark but I cannot connect RC to Spark using the above procedure.
2018-12-15
