luciens
I have the RE and the older white goggles. The RE are definitely more comfortable in the padding and with my particular head/face shape, the light leakage is less on the RE's. The white goggles bleed light from underneath pretty bad. The RE are more capable overall but the external 5.8ghz antenna is a pain. I've broken mine so many times now bumping it into things it's almost solid solder on the bottom at the connector now, which is where the antenna always breaks. The alternative is to take the antenna off every time you transport it, but that works the connector in the goggles over and over. If that ever wore out and had to be replaced, that'd be a lot more of a nightmare than just breaking an antenna .
Other than that, the RE is the way to go... |
