stand alone GPS tracker
771 10 2018-6-30
308Shooter
Does anyone use a small independent GPS tracking device on their drone?  If so, does it disrupt the flying at all and what brands are being used.  I feel this may be the best way to find one should you run into any problems or fly aways.
Thoughts??  Comments??
2018-6-30
SparksBird
Flight distance : 10731690 ft
Trackimo and PingGPS are some really good ones that some here use.  From what they have said no does not disrupt the flying at all.  Search for Dirty Bird who uses PingGPS and QuadKid who uses Trackimo
2018-6-30
308Shooter
SparksBird Posted at 2018-6-30 19:23
Thanks.... I've heard of Trackimo, but not PingGPS.... I'll look into them.  Just seems to be an extra layer of security
2018-6-30
SparksBird
308Shooter Posted at 2018-6-30 19:32
A quick search and found his thread in ping gps.  https://forum.dji.com/thread-150615-1-1.html
2018-6-30
308Shooter
SparksBird Posted at 2018-6-30 19:40
So kind.... Thank you
2018-6-30
davidmartingraf
I have a friend who uses Trackimo and swears by it as he's an older fella who's fearful of losing his Mavic Pro.
2018-6-30
I believe many use them , how successful they are is not really known, if you using with Mavic Pro , you can put it on the nose of the aircraft, don’t put on top of rear as you will block GPS receiver, also anything metal added to your drone will have some effect on your compass , so it’s advisable to calibrate with tracker on, and if you fly with it off calibrate again.
2018-7-1
308Shooter
HALLMARK007... thanks for the tidbit about the compass.  I'll definitely keep that in mind.
David...im a bit of an older fella too, and am also quite fearful.  If I were to lose it,  i definitely could not replace it.
2018-7-1
QuadKid
Flight distance : 482349 ft
I use it on my MP. MA & P4P, have to shut off the precision landing (downward sensors) when using it on the P4P, tested it a wide open field with a dirt road landed it @ 1000 meters away, the Trackimo App was accurate to 1 meter. Did not effect flight charecteristics at all.
2018-7-1
308Shooter
QuadKid Posted at 2018-7-1 03:41
WOW... 1m - That's impressive.   Seems like exactly what I'm looking for.   Does the extra weight interfere with the flying at all?   I understand about the sensor on the  P4P. but with the Trackimo on the top front of the  Mavic, doesn't that  create an unbalanced situation for the  drone?
I do love the fact that you tested it and it was accurate to 1m.   That's amazing!!  Thank you for sharing and for the pictures.
Much appreciated.
2018-7-1
QuadKid
308Shooter Posted at 2018-7-1 11:08
It has no effect at all as far as performance, I mounted it using Industrial Strength Velcro, you can get it at any Home Depot or Lowes. Just mount whatever tracking device you decide to go with in the same manner so as not to interfere with the Drones GPS receiver.
It's amazing what the Mavic Pro can carry, this is my Air (Including Battery) being transported by the MP.
2018-7-1
