![](https://forum44.djicdn.com/data/attachment/common/c4/common_1_usergroup_icon.png) Administrator
fansc99f2447 Posted at 2018-7-4 03:57
Thanks, but when the aircraft is connected, you get a prompt to disconnect it before it will allow a controller calibration, so the aircraft is meant to be disconnected.
Yes, you're right. The aircraft should be disconnected before you calibrate the remote controller. Sorry for the confusion, I'm just making sure that all the error on your end are addressed properly. May I know what mobile device are you using? For Android devices you can see the "NEXT " is greyed out and you don't need to tap on it. Please disregard next button because it will just continue once your done following the rings on the top. |
