Otg cable compatibility?
1441 6 2018-7-14
thewhatever
Lebanon
I am planning in buying a Spark on Monday, though I am searching for accessories too.
I have an otg cable micro usb to usb, my smartphone has usb c so I should an adaptet to convert micro usb to usb c, and plug a usb to micro usb for the controller, or the opposite, will it work? Or the controller needs usb 3.0 speed?
2018-7-14
As of the moment, OTG cable is still not officially recommended at present. Rest assured that we will keep improving our products to provide more option when in terms of compatibility. Your patience is highly appreciated. if you have another concern, please let us know. Thank you.
2018-7-14
Terp1234
Flight distance : 50906 ft
After reading the standard DJI disclaimers of OTG not being supported...the host part of the OTG should be connected to your remote. But I can recommend you ordering a specific OTG cable with USB C and micro USB for the Spark. You can find them quite cheap online, but then no adapters or extra cables are needed anymore and the host part is at the correct end.
Have fun and fly safely!
2018-7-14
S-e-ven
Flight distance : 5922034 ft
I think, you dont need to buy something, yet!
You have this (somehink like this), right?
If yes, just plug it to your original Charger cable, which gets into the phone
And the Micro Usb from the adapter NEEDS to be plugged into the RC, anyway
If you want to buy something, after tested with the stuff you have, go for this:
Ebay will be your friend, there!
2018-7-14
thewhatever
Lebanon
Thanks yes it's like this one. I will give it a try.
Now which filters to get? A cpl and nd 16 are enough no?
2018-7-14
DMX_MT
Malta
thewhatever Posted at 2018-7-14 07:07
Buy Polar Pro if you can. The cost more but they are the Best.
I have a set of 6pcs, some 4pcs Shutter and other 2pcs are Cinematic.
Sometime an ND32 will come in Handy when its very Sunny.
They don't give Gimbal Problems.
2018-7-14
Hi there, Kindly check this thread: https://forum.dji.com/thread-157768-1-1.html for updates about using OTG cable on spark using  Android device.
2018-7-19
