DJI assistant issue
1528 11 2018-7-24
Jeetley
Flight distance : 123944 ft
hi thereso i decided to update to the latest firmware even tho i use IOS device..on connecting my spark to dji assistant 2 and logging in i get the message on my assistant...cannot load firmware..retry...so after several attempts to load the latst firmware it pops up with the same message and i gave up.
idea's anyone one ?
2018-7-24
Sorry for all the trouble. Can  you please reinstall DJI Assistant 2 using this link: (https://www.dji.com/spark/info#downloads). Did you try to use a different USB cable? Changing the cable might help. Make sure your firewall and antivirus software is off before you reinstall the software. Kindly check the video tutorial below.
2018-7-24
Jeetley
DJI Paladin Posted at 2018-7-24 05:42
https://www.youtube.com/watch?v=1Psa4hAImKw
your link to update assistant worked fine.thank you
2018-7-24
Jeetley Posted at 2018-7-24 10:16
You're welcome. If you have another concern, please let us know. Enjoy and have a safe flight.
2018-7-25
Jeetley
DJI Paladin Posted at 2018-7-25 02:13
just to let you know..i managed to update the spark and r/c but the r/c would not connect to the a/c at all after the update ...as i have mentioned elsewhere on this forum yesterday.
i downgraded the firmware back to the previous release and every thing worked fine..again.
there was an issue with that firmware update.
iOS user...UK
2018-7-25
Jeetley Posted at 2018-7-25 09:30
Hi, sorry for the troubles, did you manage to update the RC upon updating the aircraft?
2018-7-25
Jeetley
DJI Tony Posted at 2018-7-25 12:41
yes tony i did..when i downgraded the firmware it was on the a/c only as i did not know how to downgrade the r/c
2018-7-26
Jeetley Posted at 2018-7-26 00:13
Hi, thanks for the feedback, were you able to locate the wi-fi name of your RC? unfortunately, we don't have an official process of downgrading the firmware of the RC.
2018-7-26
Jeetley
DJI Tony Posted at 2018-7-26 09:06
not sure what your asking me there but i connected the iOS device to the R/C successfully but the r/c would not locate the spark.
wifi r/c  654176
2018-7-27
Jeetley Posted at 2018-7-27 03:02
wifi r/c  654176
Hi, thanks for the response, I would like to clarify that the phone will connect to your remote controller's wifi correct, however, the RC will not connect to your drone, correct? I would suggest linking the RC to the aircraft without using a phone. Please see the video below.
2018-7-28
Jeetley
DJI Tony Posted at 2018-7-28 03:00
https://www.youtube.com/watch?v=GOi9WiS-PF8
yes dji Tony you are correct.
but i never use the phone to connect the r/c to the aircraft i always use the relevant three buttons on the r/c to connect, like i said after installing the latest firmware the r/c would no longer connect, the light just kept on blinking red all the time the front LED's were flashing red.
i tried several times powering on and off both units several times also.
the only thing that worked was downgrading the firmware on the a/c to the previous version.
2018-7-29
Jeetley Posted at 2018-7-29 04:06
Hi, sorry for the late response, would it be possible if you can provide a short video of this issue? you can use google drive or drop-box then provide the link here. Thank you.
2018-7-29
