spark not connect to DJI Assistant 2
6028 18 2017-12-16
serezhka
Flight distance : 1067474 ft
spark not connect to DJI Assistant 2. not connect to wi-fi
2017-12-16
Wachtberger
Flight distance : 261509 ft
Are you on Windows 10? Try re-installing the DJI Assistant and check if you get any driver related message. After all it has worked for me.
2017-12-16
serezhka
Wachtberger Posted at 2017-12-16 01:06
Thank you. all this has already been done. I have Windows 7. Phantom 4, Mavic - it works.
2017-12-16
serezhka
serezhka Posted at 2017-12-16 01:19
[12:22:17][DevMgr              ] DLL : DJIBatteryHub        ignore!
[12:22:17][DevMgr              ] DLL : DJIFlightDataService ignore!
[12:22:17][DevMgr              ] DLL : DJIRadarService      ignore!
[12:22:17][DevMgr              ] DLL : DJIUsbService        ignore!
[12:22:17][DevMgr              ] DLL : DJIWatchService      ignore!
[12:22:17][DevMgr              ] DLL : In2UsbReader         ignore!
[12:22:17][DevMgr              ] DLL :  PathPlanningService Doesn't Support Standard API!
[12:22:17][DevMgr              ] Device Arrival : RNDIS_DJI_PHANTOM4_RNDIS&COM4
[12:22:17][DJIDeviceCommandIo  ] open RNDIS_DJI_PHANTOM4_RNDIS&COM4
[12:22:17][SerialIo            ] Open COM4 success!
[12:22:17][DEV_ID              ] open device succeed
[12:22:20][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:23][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:23][dServer             ] 1    Connected <- root
[12:22:26][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:29][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:32][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:35][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:39][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:42][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:42][dServer             ] 2    Connected <- root
[12:22:45][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:45][dServer             ] 3    Connected <- root
[12:22:48][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:51][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:54][Serial2             ] Write Data Timeout! Wait = 3000
[12:22:57][Serial2             ] Write Data Timeout! Wait = 3000
[12:23:00][Serial2             ] Write Data Timeout! Wait = 3000
[12:23:03][Serial2             ] Write Data Timeout! Wait = 3000
[12:23:03][dServer             ] Disconnected! /general, root
[12:23:06][Serial2             ] Write Data Timeout! Wait = 3000
[12:23:06][n1860_idf_RNDIS_DJI_] get version timeout!!!
[12:23:06][SerialIo            ] Free COM4 success!
[12:23:06][CommandIo           ] DJIDeviceCommandIo closed.
[12:23:07][DJIDeviceCommandIo  ] open RNDIS_DJI_PHANTOM4_RNDIS&COM4
[12:23:07][SerialIo            ] Open COM4 failure,error:5!
[12:23:07][D_IO                ] Can't open port COM4, Unknown error
[12:23:07][DEV_ID              ] open device [RNDIS_DJI_PHANTOM4_RNDIS&COM4] failed
[12:23:08][DJIDeviceCommandIo  ] open RNDIS_DJI_PHANTOM4_RNDIS&COM4
[12:23:08][SerialIo            ] Open COM4 failure,error:5!
[12:23:08][D_IO                ] Can't open port COM4, Unknown error
[12:23:08][DEV_ID              ] open device [RNDIS_DJI_PHANTOM4_RNDIS&COM4] failed
[12:23:09][DJIDeviceCommandIo  ] open RNDIS_DJI_PHANTOM4_RNDIS&COM4
[12:23:09][SerialIo            ] Open COM4 failure,error:5!
[12:23:09][D_IO                ] Can't open port COM4, Unknown error
[12:23:09][DEV_ID              ] open device [RNDIS_DJI_PHANTOM4_RNDIS&COM4] failed
[12:23:10][SerialIo            ] Open COM4 failure,error:5!
[12:23:10][D_IO                ] Can't open port COM4, Unknown error
[12:23:10][DEV_ID              ] open device [RNDIS_DJI_PHANTOM4_RNDIS&COM4] failed
2017-12-16
Wachtberger
serezhka Posted at 2017-12-16 01:24
In this case I have unfortunately no idea either... Sorry that I couldn't help more. Do you maybe have the opportunity to try on a different PC?
2017-12-16
Lyons90
Flight distance : 164528 ft
Spark turned on before plugging it in?
2017-12-16
serezhka
Wachtberger Posted at 2017-12-16 01:26
on the other computer is the same. Thank you very much for trying to help.
2017-12-16
Wachtberger
serezhka Posted at 2017-12-16 01:37
You are welcome and I hope that somebody else will be able to help you. Good luck!
2017-12-16
serezhka
Lyons90 Posted at 2017-12-16 01:36
all options were
2017-12-16
fans0fdf77f1
Flight distance : 18346 ft
Malaysia
I m having the same problem, i uninstalled and install using 'safe mode' in window 7 , maybe your antivirus interference when u installed in normal window s mode..hope it helps
2017-12-22
DJI Elektra
Hi, sir. Did you solve the problem now? Can you charge your spark with recommended charger?
2017-12-24
Jiker69
Flight distance : 2168773 ft
Nothing works for me, I'm using Windows 10.
2018-6-26
landude
Flight distance : 126407 ft
In Windows 10 you have to go into settings then reboot to a menu where you have the option to turn on install unsigned drivers. Search for that, it will allow your drivers to install.
https://www.google.com/search?so ... 0k1.252.KKpBc136_lQ
2018-6-26
Jiker69 Posted at 2018-6-26 10:34
Hi, sorry for the trouble that it caused, I would like to verify, what is the version of your DJI Assistant 2? Is it possible if you can provide the screen-shot of what you're seeing when you connect your spark?
2018-6-27
Jiker69
landude Posted at 2018-6-26 17:08
https://www.google.com/search?source=hp&ei=NOMyW53ZBMHJ5gK9zo7oCA&q=windows+10+installing+unsigned+drivers&oq=windows+10+installing+u&gs_l=psy-ab.1.1.0l8j0i22i30k1l2.630.6170.0.8402.25.23.0.0.0.0.300.2976.1j11j4j1.18.0..2..0...1.1.64.psy-ab..7.18.3224.6..35i39k1j0i131k1j0i20i264k1j0i10k1.252.KKpBc136_lQ
Thank you, I'll give that a try.
2018-6-27
Jiker69
DJI Tony Posted at 2018-6-27 11:04
Version 1.2.4
I see nothing and there is not a connected device in File Manager.
2018-6-27
Would it be possible if you can provide the screen-shot of the issue?
2018-6-28
fans7d848bd0
Flight distance : 152533 ft
I just went through this experience and in the end found it to be a simple issue.  I finally used the cable that came with the drone and it connected to my WIN10 system.  Two other cables wouldn't connect although they would charge the battery.  Evidently they weren't sufficient for data.
2018-8-26
Jose98
fans7d848bd0 Posted at 2018-8-26 11:34
2018-8-26
