mavic 2 sensor calibration
11537 31 2018-8-27
WickedWingman
so at during the calibration, it asks you to fold the rear arms to calibrate some sensor.  you can't fold the rear arms with the usb cable plugged in!
2018-8-27
msinger
Flight distance : 228255 ft
The video below shows how to perform the calibration. As shown in the video, you just need to fold the leg far enought to ensure it's not blocking the side sensor.
2018-8-27
Hi there. Thank you for reaching out and sorry for some inconvenience. Regarding with that you can check this video tutorial on how to calibrate it.
2018-8-27
WickedWingman
that's exactly what i did, but i couldn't get it to continue the calibration.  probably user error.  i'll try again later.
2018-8-27
Anthony566
Flight distance : 2488944 ft
Did they need calibrating ???
2018-8-27
WickedWingman
I was bored waiting for DJI assistant to find the new firmware, so I decided to play with calibration.
2018-8-27
WickedWingman Posted at 2018-8-27 13:38
Hi. Please let us know on the latest progress. Thank you for the support.
2018-8-27
WickedWingman
The sensors seem fine. Took my maiden flight tonight, so I likely won't bother trying to recalibrate unless I have to.
2018-8-27
WickedWingman Posted at 2018-8-27 16:02
Thanks for keeping us updated. Glad to hear the drone works now. If there is any further question, feel free to contact us. Wish you have a good time!
2018-8-28
Asainz320
Flight distance : 1061594 ft
Im having issues with the calibration on my Mavic 2 Zoom. I complete all the calibration steps successfully but in the end it stays at 0% on Calculating. What could be the issue here?
2018-9-14
MHB
Having the same issue with the Mavic 2 Pro. All went well and stuck on this screen! Ugh
2018-9-18
Parisi2274
Flight distance : 212434 ft
So I was calibrating my Mavic 2 Pro tonight in Assistant and for whatever reason it only asks me to calibrate the front and bottom sensors, and I am not sure if its just the standard graphic, but in the animated gif, it shows a maiv air body and not the Pro.... Any ideas??
EDIT: Nevermind!  Did not realize that there was a new version of Assistant out for the Mavic 2 Pro.  All is good now!
2018-9-19
MHB
Parisi2274 Posted at 2018-9-19 19:04
It didn't work for me stuck calibrating after I went through all the steps at 0%. See my post above. Anyone else have this issue and get it to work eventually and how?
2018-9-20
Scanners
Flight distance : 89990 ft
I just received my Mavic 2 Pro. I have updated to v1 of the firmware and I am using DJI Assistant 2 for Mavic 2. I went through the 4 step calibration tutorial, but the Calibrate Now button remains gray - never becomes active. Have waited up to 30 mins. Tried multiple times. First time through it baulked at my ultrawide monitor, so disconnected it and tried again on a 27" HD, then on my laptop screen with no other screens attached - nothing!
Any help appreciated.
2018-9-20
CameronW
MHB Posted at 2018-9-18 17:53
Having the same issue with the Mavic 2 Pro. All went well and stuck on this screen! Ugh[view_image]
I am having the problems did you ever figure it out
2018-10-14
Chilo
CameronW Posted at 2018-10-14 13:28
Same here, tried over and over again, keeps getting stuck at 0%
2018-10-30
SH3RMAN91
same problem with my mavic 2 i'm unable to calibrate vision sensor, it stay stuck at 0% on dji assistant 2 !
Does anyone can help us to fix this ?
Best regards
2018-11-12
DSS12
MHB Posted at 9-18 17:53
Have you found a solution? I am having exactly the same proble. dsiegel@smith.edu
2018-11-18
DSS12
Make sure that you are using Assistant  2 for Mavic 2 and not just Assistant 2 for Mavic   You can get it from the DJI Mavic 2 website, and the current version is 2.0.4.
2018-11-19
walttheartist
Flight distance : 46696 ft
Asainz320 Posted at 9-14 14:26
I have all the latest firmware and software updates installed and I'm having the same problem. Tried to calibrate twice and got as far as the 0% progress bar, then it stalled.
2018-11-19
ruggbg
What I learned.......
1st, this SW has a problem with some screens especially desktops. I got it to work on both my laptops but could not find a resolution it was happy with on my desktop. One laptop I had to set the resolution at 1600x900 then set the screen size to the same (set resolution, not physical size). The other worked fine immediately at 1920x1080.
2. when you follow the blue box, TILT the AC do not slide it across the screen. Keep the center (where you are holding it) in one spot.
2018-12-5
djiuser_gHJmr4psH3tN
Flight distance : 13953 ft
I have  the  same issue  with 0% after all calibration are done. DJI Mavic  2 zoom. I use DJI assistant 2 for 2.4 version for Mavic  2 pro. I run calibration  3 times, with the same 0% result at the end. Any ideas how to fix, or wait until  DJI software  guru will figure out  how to fix and update Assistant 2?
Sincerely,
Sergey
2018-12-9
Sincerely,
Sergey
2018-12-9
JABB
Flight distance : 24701 ft
ruggbg Posted at 12-5 18:02
486/5000
(Excuse me for my English)
I had the same problem as some of you.
When I have seen the response of the friend RUGGBG I have found the solution.
I had done the calibration test 8 times, proving with different monitors and always the same result, in the end when you have to present the results put the message "calibration error."
I tested it directly with the laptop screen and the first one worked. Result of calibration "OK"
(DJI Assistant 2 For Mavic 2.0.6.exe)
Thank you.
2018-12-25
HereForTheBeer
Flight distance : 5381368 ft
my mavic air wont even start calibration.. just sits there on white screen.. :/
2018-12-25
tchriste
I crashed yesterday and since then I have had the  Forward Right Vision Sensor Error. I've attempted to calibrate using DJI Assistant 2. However, during the calibration process one of the sensor status screens (right) is black. I am guessing its a bad sensor. eek
2019-1-22
Sandesh Seema Sudhakar Bhosale
hi i am try to connect my aircraft with my PC but only my computer read that file . its not open with DJI software. please assist me ?
2019-3-16
JJMik
Flight distance : 24572349 ft
I have done it many times and I am always stuck At calculating  nothing happens
2019-4-14
Boizom Gangte
Stuck here. Dji assistant is one app that did not help.my middle finger salutes the app creator.
2020-1-10
Boizom Gangte
djiuser_gHJmr4psH3tN Posted at 2018-12-9 17:47
Sincerely,
Sergey
I'm also in need of this solution
2020-1-10
SergeGotz
Same here. I'm already a couple of days into this and I think it's really a shame that DJI doesn't come up with a good solution in stead of telling people to try other screens and computers and whatever more. They obviously haven't solved this problem which exists already a couple of years and apparently they also stopped answering in forums.  It's very clear that this is a software problem, so DJI, don't push us into one of your stores to have this solved and of course to spend money again, while I could have done this myself. Fix this problem like a decent company would!
2021-1-23
ptwalsh601gmail.com
Anyone can help me my side sensors aren't working on my mavic 2 Pro so I connected it to my laptop dji assistance 2 calabreated it and it says completed but the side sensors  still not working..anyone have any idea what the problem could be ??
2021-2-16
