Goggles RE are disturbing signal with Mavic 2 Pro
8476 58 2018-9-15
JK JK
Flight distance : 652552 ft
It seems the RE disturbs the signal between R/C and M2P, when I power off the RE, the signal is ok. I cann't flight more than 200 metres in open area.
What is bad?
2018-9-15
A CW
Flight distance : 14588274 ft
Good to know.
2018-9-15
DJI Natalia
Hi, sorry for the inconvenience caused. Can you please try to refresh the firmware of your DJI Goggles via DJI Assistant 2? Let see if this will work. Thanks.
2018-9-15
JK JK
Czechia
I have the latest .600 FW for goggles RE, also the latest ones are installed to the drone, its R/C and all batts.
The windows app still offers "Update" even thought it shows the latest one is already installed.
2018-9-15
DJI Natalia
JK JK Posted at 2018-9-15 09:30
Hi. Can you please try to connect your drone to DJI Assistant 2 via PC and refresh your firmware? Please try to reinstall your DJI Go 4 app too.
2018-9-15
JK JK
I will try and let you know the result.
2018-9-16
Rblomqvist
Flight distance : 1026260 ft
I had similar problems. Try to install the antenna, that was the thing that solved it for me.
2018-9-16
JK JK
The antenna is dedicated for analog 5,8. It is mentioned in the manual and DJI FAQ
2018-9-16
Rblomqvist
JK JK Posted at 2018-9-16 20:57
That was my understanding as well, but after trying it, my conclusion is the antenna makes a big difference. Pls see this thread about this topic: https://forum.dji.com/forum.php? ... p;page=1#pid1560011
2018-9-17
Georgedaoud
Flight distance : 576952 ft
I HAVE THE EXACT SAME PROBLEM!!! IT IS SOOOO FRUSTRATING!!! I have the mavic 2 zoom and I lose signal with the RE goggles at around 1000 m, then i just disconnect the goggles and the signal returns perfectly fine with the controller alone. I have the antenna plugged into the goggles and still it cuts off no matter what. I even took it to an area with no interference, yet still, the DJI Goggles RE lost range with the magic 2 zoom again at around 1km. Anyone with any solutions?
2018-9-17
JK JK
Rblomqvist Posted at 2018-9-17 03:29
That was my understanding as well, but after trying it, my conclusion is the antenna makes a big difference. Pls see this thread about this topic: https://forum.dji.com/forum.php?mod=viewthread&tid=165790&page=1#pid1560011
The issue is pointed to the fact the signal between the  aircraft and r/c is blocked by the goggles.
2018-9-19
YorkshirePaul
Flight distance : 1315404 ft
Exactly same problem - seems very common. Come on DJI please admit it’s a problem. I’m ‘happy’ to accept it if a firmware update will resolve this, otherwise do the right thing and offer money back.
2018-9-20
fans24fd6668
YorkshirePaul Posted at 2018-9-20 13:44
Same problem here in NZ. If I try to take the drone over 100 ft with the goggles the videogoes blocky and the RC loses control of the aircraft.
Turn off the goggles and after  a few seconds control is restored and video restored.
2018-10-20
fans24fd6668
fans24fd6668 Posted at 2018-10-20 20:13
Hi. Today 22/10/18 I just updated the RE goggles firmware using DJI assistant 2.02  from Vol-00.0600 to Vol -00.0700 which is supposed to be the latest.
Took it out for a fly. Over sea. No interference for miles.
Video started to get choppy at 250 ft and I lost manual control from the controller and the Screen froze in black and white.
When I turned off the Goggles everything came back to normal within a few seconds. Control regained and all ok up to 450 ft.
goggles are definitely  the problem.
Tony
2018-10-21
fans9c9010a5
Flight distance : 174865 ft
I'm have the same issue. Mavic 2 Pro and RE Goggles. Can only fly to 100 feet or so then signal goes bad. Unit wants to fly home. Making sure I'm on the latest firmware.
2018-10-27
fans9c9010a5
Made sure I was on. The latest firmware on everything and still experiencing the same issue at 100 feet I lose signal.
2018-10-27
fansbe73aa5b
Flight distance : 588550 ft
Exact same issue. Seems as soon as i go past 100 feet i lose signal on the goggles. I can still control the drone though
2018-10-27
Rfern
Flight distance : 482805 ft
Same here!!!!!This I B.S. There is multiple threads on this , including mine. Almost $600 for trash. Hey DJI, FIX IT OR GIVE US OUR MONEY BACK!!!!
2018-10-28
buddhaholic420
Same issue on latest firmware. I am going to call DJI today to see what they say. I hear the customer service sucks. Lets see.
2018-10-29
buddhaholic420
buddhaholic420 Posted at 2018-10-29 07:45
Called and they had me factory reset by reupgrading it. Same results. I am on the phone again with them trying to see what the next step is for a resolution.
2018-10-29
bjr981s
Flight distance : 139698 ft
Can everyone post their country location and what smart device android / IOS they are using.
Occusync 2 uses both 2.4 and 5.8 for transmission of Video and RC control.
This looks similar to the Spark problem where it was switching to channels unavailable in the local country.
2018-10-29
Rfern
bjr981s Posted at 2018-10-29 09:13
I’m in USA , Upstate New York. I’m using an IPhone XR. All the latest firmware refreshed.
2018-10-29
Rfern
I was using an iPhone SE and it still sucked but it seemed better than the new XR as far as range goes
2018-10-29
04in719
Flight distance : 151 ft
M2Z and M2P with Goggles (not the RE Goggles).
Both birds have latest FW, Goggles have latest FW.
Both have very limited range when using using goggles. As I understand it when using the goggles the AC only does 2.4GHz? Perhaps why the limited range?
When Goggles are turned off most of the time the range issue is resolved but I have experienced not being able to switch the channel back to "both". Restarting AC and RC "fixes" it till next time I want to use the Goggles.
Dear DJI, please do your best to resolve this. It's just not acceptable and completely mitigates any reason to own the Goggles at all.
2018-10-30
towheaded-pilot1
Flight distance : 35125 ft
I'm having similar issues here in the US. With Occusync 2 at 2.4ghz, I'm able to use the goggles but get lag at random. Occusync in auto, not good. Also constantly getting interference warning in the go app as well. Tried using Android app, IOS app and CS.
2018-10-30
towheaded-pilot1
JK JK Posted at 2018-9-19 09:25
How is it possible that the r/c is block from goggles? You are holding the r/c and goggles on your head. There is nothing blocking. I think this has something to do with the transmission signal bumping to each other.
2018-10-30
Rfern
Aren’t these things tested before they’re released? This is borderline criminal!!
2018-10-30
Georgedaoud
Rfern Posted at 2018-10-30 16:01
LITERALLY! It's Disgusting!
2018-10-30
fansdf1984e2
Flight distance : 74941 ft
I want to buy the white goggles as soon as this range issue is resolved so dji get to work!
2018-11-4
FlyingAnt
Flight distance : 440190 ft
I have exactly the same issues with my M2Z and Goggle RE. Got in touch with DJI and they told me to return the goggle as it may be faulty to be replaced with a new one. The new replacement goggle arrived and guess what same problem!
2018-11-6
fans24fd6668
fans24fd6668 Posted at 10-21 22:27
Just to update. Took the RE Goggles and Mavic back to DJI Agent here. Ferntech Auckland . They tested it and found the same problem also with the Mavic pro Zoom. Seems like a firmware issue. Immediate problem can be solved by a workaround. Connect Goggles to R/C with USB but that is really not satisfactory.
They have notified DJI of the issue and hope to hear back from them soon as.
tbony
2018-11-6
Rfern
Thank you for the update. Pretty sad that DJI could not tell us this.
2018-11-6
bjr981s
Strange,
I have been flying my Mavic 2 Pro and my Mavic 2 Zoom with RE goggles and have had no Issues. I am using a Crystal Sky UB as my smart device.
I assume that everyone is tuning off wifi and BT from their smartdevice when flying? and their applewatch series 3 and 4 if they have one.
2018-11-9
jmclfrsh5621
Flight distance : 5607 ft
Unfortunately, for many of us, buying a $1000 monitor to fix a $500 set of goggles is a step in the wrong direction, and undoable.
2018-11-10
Mavical
Flight distance : 2206696 ft
Question for the group,
Has anyone come up with a workaround to bypass the wireless connection on the RE Goggles and link it directly through the USB hub with a cable on the Mavic 2 Pro’s RC?
2018-11-12
Andrew EF
Flight distance : 3151388 ft
I want to know when DJI is going to fix this!?
2018-11-20
$gambino$
Flight distance : 1563980 ft
Mavical read  back a few posts! That Ppears to be the suggestion .....use bottom usb on remote
2018-11-21
Mavical
Pasted below is the reply from DJI in regards to connecting the RC to the Goggles RE directly with a cable… if they are wrong can someone else on here provide steps on exactly which ports and cable to use. Thanks
_______
Good day and thank you for contacting DJI Technical Support.
We appreciate the time and effort you spent in reaching us. We are sorry to hear that you are having issues using the DJI Goggles RE using wireless connection. We understand that you are asking for directions on how to connect your Mavic 2 Pro using an HDMI Cable.
With regard to connecting your Mavic 2 Pro to your DJI Goggles RE using an HDMI cable, I'm afraid to inform you that the HDMI connection between the DJI Goggle Re and the Mavic 2 Pro is not available. Currently the DJI Goggles RE can only be connected to the Mavic 2 thru wireless connection. We apologize for  any inconvenience that this may cause you.
Thank you and have a great day.
Best Regards,
Don
Website: [url]http:
2018-11-28
Jose C. Borrero
Flight distance : 1170768 ft
Puerto Rico
It sucks. I tried the aluminum foil and improve a little,also it works better with the antenna.
try and post your opinion
2018-11-29
Mavical
Since it might be a while (or never) in regards to DJI putting out a fix on the widespread M2P to Goggles RE range issue, I am looking for suggestions or a hack to connect / hard wire the RC to the M2P
I already tried connecting from the USB port on the bottom of the RC to the micro HDMI port on the Goggles RE with no success.
I am wide open to trying any ideas that anyone has here on how to hard wire the two together…
2018-11-30
