Should I worry and what to do?
1301 19 2018-10-1
Tomislaw
Croatia
He!
This is my first post here, of course, because of a problem
The drone was set in to the Quick Shot mode (Circle), it began OK; in one moment it began speed up and then happened this. There was no errors. Here are the flights records. It was a bit windy, but there was not one warning about high wind velocity. Should I be worried? After this I did the same day another 3 or 4 flights, and it was all OK, except I became the mesage I should calibrate the obstacle sensors.
Here are the flight data.
https://app.airdata.com/share/TnrORQ/GENERALOverview
2018-10-1
Flight distance : 10186312 ft
Was this on new FW .500 ?, wind could have been a factor, it looks like your gimbal was on a bit of a wobble, you could try calibration of sensors and IMU and gimbal calibration.
There was obviously something wrong, if after calibrations it’s still the same you might have to raise a case with dji .
2018-10-1
Hi there, thank you for reaching out and we're very sorry for the trouble what you experience. Regarding that may I ask have you try to calibrate the IMU and Compass? and have you already calibrated the sensors?
2018-10-1
STRIDE8
Flight distance : 1382431 ft
WHOA.. thats scarey
2018-10-1
dor4x
Flight distance : 2320256 ft
Israel
I had something similar today in normal flight
I did the firmware update yesterday.. and I am afraid it is connected
2018-10-1
FlyDK
Flight distance : 1636286 ft
Holy smoke, that looks strange.
2018-10-1
Tomislaw
Croatia
hallmark007 Posted at 2018-10-1 07:39
I will look at the current firmware version, but I have always the latest firmware, and between this date and today there was no updates.
2018-10-1
Tomislaw
Croatia
DJI Stephen Posted at 2018-10-1 07:46
I did the same day another 3-4 flights without any trouble. I did a Sensor calibration when i come home. The IMU was never calibrated (no errors), but I muss calibrate the compass from the first day allmost every time when i drive the bird in my car.
2018-10-1
Nordium
Flight distance : 10875728 ft
Calibrate your compass and sensors and then make sure that they're all in good standing. From the video you shared, it seems as if your gimbal completely turned off. Strange.
Let us know if you experience this again! Thanks for sharing.
2018-10-1
Tomislaw
Croatia
Nordium Posted at 2018-10-1 10:23
As I said, i calibrate the compass almost on the regular basis. But what it a bit strange in my opinion, if you look at the beginning of the video, it seams that the drone at one moment begin to speed up (0:15), or is that just my wrong perception?
2018-10-1
biob_mav
Flight distance : 53612 ft
Your logs say you had selected Active track, what were you trying to track? It’s used for people/vechicles This may be what caused the issue?
Did you mean to use point of interest? Circles around a selected building etc.
2018-10-1
Tomislaw
Croatia
biob_mav Posted at 2018-10-1 11:43
The logs say active track, I say, quickshot (circle). I selected the white tent in the backyard in the middle of the shot. I do not use often any kind of quickshots, so if anyone know do logs make a difference between the shots?
2018-10-1
biob_mav
Those modes are for close up shots. For what you where doing I think you should of been using POI.
2018-10-1
biob_mav
This is for spark, but it’s the same for Mavic Air too. It’s example uses for Quickshot modes
2018-10-1
Tomislaw
Croatia
biob_mav Posted at 2018-10-1 11:57
I hope you are right. This would save me from the problems in the future.
2018-10-1
biob_mav
2018-10-1
Nordium
Tomislaw Posted at 2018-10-1 11:10
If you refer to your flight log, it will tell you the speed (you should be able to tell if it sped up at this point or not). To me, it seems as if the drone did in fact speed up; however your gimbal did turn off which created a lot of shakiness, which could easily make it seem as if the drone was moving faster than it actually was.
Sorry for not acknowledging that you calibrate your compass on a regular basis in my first response, I've been replying to quite a few people on here today trying my best to help them with their specific issues, therefore my mind is kinda hazy.
2018-10-1
Lucas775
Flight distance : 50642090 ft
Common sense: just because there is no "high wind velocity" warning it doesn't mean you can fly it through a hurricane.
2018-10-1
GDL
Flight distance : 2768694 ft
Some people reported POI mode may fall into the centre at end. Not sure this problem fixed in .500 firmware or not. Be very careful when flying in automatic modes.
2018-10-1
Tomislaw
Croatia
Nordium Posted at 2018-10-1 17:34
In any case, thanks.
2018-10-2
