Best Phone or tablet for SPARK
3333 20 2018-10-17
djiuser_oaUP1jBksftJ
Flight distance : 1762 ft
I would like to know what is the best platform to use with the spark w/remote controller.
I believe I have narrowed down my auctions to either iPad Mini 4, a newer iPhone or the Samsung Galaxy Note 9.
I have the OTG cable so I would be able to directly connect the remote control with the device via USB etc.
2018-10-17
DJIJAKOB
Flight distance : 740577 ft
The iPad Mini 4 works very well, it also fits inside the remote controller brackets so you won't need a tablet adapter. Personally I use the Samsung Galaxy S9 normally and it works with no problems. Galaxy Note 9 will also work fine.
2018-10-17
Hi there, thank you for reaching DJI forum. You can check our recommended devices below. If the phone or tablet is not listed below, there's a possibility that it will still work fine however we cannot ensure if you can use all the features and functionality on the APP. Please let us know if you have other concern, we're here to help.
2018-10-17
Thank you for the information.
My other question regards the OTG cable how is that working with the note 9 or the I mini.
Issues I'm having right now our video. I'm flying in tripod mode 30 frames per second manual settings on video yet my video I'm getting a slight vertical rolling while filming what I mean by Rolling is a noticeable line scrolling up the screen. Any ideas suggestions
2018-10-17
DJI Paladin, thank you very much for that list of devices. Also does the OTG cable reduce video interference and actually assist with video.
2018-10-17
KlooGee
Flight distance : 16783757 ft
djiuser_oaUP1jBksftJ Posted at 2018-10-17 07:02
Can you post a screen capture of what you are seeing with the vertical rolling?
2018-10-17
Hope you can see it in the video. I downloaded this video direct from the spark to my phone so it came directly from the SD card via remote to my phone
2018-10-17
msinger
Flight distance : 228255 ft
You can find a list of recommended and commonly used mobile devices here:
Best Tablets and Phones for DJI GO (Updated Daily)
2018-10-17
Hope you can see it in the video. I downloaded this video direct from the spark to my phone so it came directly from the SD card via remote to my phone.
Link:
https://www.skypixel.com/pilot/videos/share/video-roll-with-spark
2018-10-17
KlooGee Posted at 2018-10-17 07:22
2018-10-17
30 fps, man, Filter ND16-PL
2018-10-17
KlooGee
This looks like you are using the low-res cached footage on the phone rather than original footage from the SD card in the aircraft itself.  Could that be the case?
I'd recommend checking the footage directly from the SD card on a computer.
2018-10-17
KlooGee Posted at 2018-10-17 07:54
Yes, could be. I'm going to take the SD card out and DL it to my PC right now.
Thanks alot for assistance
2018-10-17
Alex B.
Flight distance : 21105262 ft
I use iPad Air 2 and it works perfectly.
Flysafe
Alex
2018-10-17
So I downloaded the video directly from the SD card to my PC. Still had the video roll. I shot some more video yesterday but I used a different filter over the lens. The video did not have the role so I'm wondering if maybe the filter which was a ND 16 PL had anything to do with it. Strange though. Still trying to figure out the best settings for a sunny day shutter speed filter Etc
2018-10-18
Alex B. Posted at 2018-10-17 11:48
Flysafe
I'm looking at an iPad Mini 4 256gb right now. I think that is a good mix of size and weight and screen ratio
2018-10-18
Alex B.
djiuser_oaUP1jBksftJ Posted at 2018-10-18 05:32
Yes it’s ok.
Although I would worry a bit about the compatibility of iPad mini 4 with the upcoming versions of DJI go 4, just because some users reported issues with their iPad mini 4 running the latest app versions.
Fly safely
Alex
2018-10-18
Stray Cat
Flight distance : 35502 ft
I have a Galaxy Tab A 10.1 (2016) and no problems using OTG or WiFi. Bought an adapter to fit to remote phone brackets. (Skyreat Mavic Air Pro Foldable Aluminum-Alloy 4-12" iPad Tablet Mount Holder for DJI Mavic 2 Pro, Mavic 2 Zoom/Mavic Pro/Mavic Air, DJI Spark Accessories Remote Controller)
2018-10-18
jacksonnai
Well if you want huge screen then the Ipad mini 4 will be the great choice. Read here for more https://www.phantomhelp.com/Tips/best-tabletsphones-for-dji-go.18
2018-10-19
I noticed something yesterday. While using the 16 filter, I had the video roll. These are Polarpro. Strange, maybe the cam is getting confused with the filter?
2018-10-19
Stray_Cat, sounds like a nice setup
2018-10-19
