Video starts great and then goes into slow motion
913 5 2018-11-28
danevans1985
Flight distance : 16722 ft
Hi everyone
I shot a video today of a round about and then wanted to speed the cars up to turn an 8 minute video into 1 minute. I edited it on DJI go and everything was fine then all of a sudden it 10 seconds into the video it goes into slow mo. I can’t figure out why. Any help would be great.
Dan
https://share.icloud.com/photos/0u3gSG7gzosWXjAWEVi9Q0WLA
2018-11-28
Wolferl
Flight distance : 23793 ft
Austria
Hi Dan,
That video does not play correctly, it seems to be totally goofed up. It is jumpy, shows bad artifacts, does not play on VLC at all.
Do yourself a favour and use a decent video editing software for your computer to create the video the way you want. Smartphone are not really suitable for that IMHO.
Cheers,
Wolferl
2018-11-28
A CW
Flight distance : 14416132 ft
What micro SD card are you using
2018-11-28
Hello and good day danevans1985. I am sorry to know that you are having this issue on the video taker with your DJI Spark. Is this the first time that this issue happened to your videos? May we know the model and the specification of the SD card that you have? For us to check if the SD card is recommended for your DJI Spark. Thank you.
2018-11-28
danevans1985
DJI Stephen Posted at 11-28 10:22
I am using the SD card I got with my flymore package at DJI New York. It is a Lexar 633x 16gb. I hope that helps
2018-11-28
fans2c917c03
I have been having the same problem for about a month now. The first 10 seconds play fine then everything slows down.
It seems that it happens more on longer clips with high speed increases.
For instance, I speed the clip up 5x then render it to my iPhone, then when I play it, the first 10 seconds play at 5x (with the sound correct at 1x) and then the rest slows back down to 1x (with the sound at 0.2x). The file length shows correct on the iPhone (example 40 seconds) but when you play, it takes 3-4 minutes.
To confirm, before it is rendered out of the DJI app, it plays correct in the DJI editor at the correct speeds.
Any help on this same issue would be appreciated.
2018-12-14
