Stripped motor spindle threads
3359 7 2014-12-7
rare1a1
Well I purchased my p2v+ used but only had 3 flights. Prior owner touted the carbon fiber blades. Of course I immediately ordered dji replacements.  One prop would not unscrew so I had to use pliers.  Yes, I was turning the correct direction.  Anyway the top three threads on the motor spindle are totally stripped and destroyed.  Can that outer hub of the motor be replaced or am I looking at needing to replace the motor?  I do see what appears to be a very small hex screw on the spindle.
2014-12-7
Dboy
China
Well..it's hard to fix the thread if the thread is distorted. The twisted thread could be rubbed down to avoid blocking the blade, but the whole process may cost lots of time.
Normally the motor are provided as a whole part, finding a single gear needs good fortune
P2V+ uses 2312 motor which could get from Dji or other website.
2014-12-7
rare1a1
Yea that's pretty much what I figured thanks dboy
2014-12-8
jamesnns
Here's the way Iv repaired stripped threads in the past when getting a new part was expensive...
Take your P2 to the hardware store (only if you dont know the exact threading of the spindle) and match up a stainless steel nut to a spindle that isnt stripped. Buy 4 nuts. Get home, put nut in ratchet set that matches nut, put nut on stripped spindle, turn 1/8th to 1/4 turn while holding motor stable with wrench. Back off nut each turn  Repeat until rethreaded.
it does take some time, but an easy try before you go replacing a motor just cause a spindle is stripped.
Or i suppose you could bring a prop, match up a bolt, then find the nut that way.....prob easier
2014-12-8
rare1a1
Yea I don't believe they're a standard bolt thread.  There's too much metal loss to re thread even if I had the proper thread cutter
2014-12-8
Gerry1124
rare1a1@gmail.c Posted at 2014-12-9 02:06
Yea I don't believe they're a standard bolt thread.  There's too much metal loss to re thread even i ...
You can get replacement motors for the stock phantom 2 v+ for $18.00 each.  for cw and ccw.  part 10 and 11.  www.dronecamps.com
2014-12-8
rare1a1
Thanks Gerry just spoke witth them. Gonna go ahead and buy the new v3 escs & motors
2014-12-8
Dboy
China
rare1a1@gmail.c Posted at 2014-12-8 23:25
I am sorry that the motor should be 2312 rather than 2212 according to DJI spec
And I have corrected it in my former reply.
2014-12-8
