DJI Smart Controller CPU & Hardware Specs
8213 16 2019-1-19
mAIRs
Does anyone know what the CPU, RAM and Chipset specs are in the new DJI Smart Controller?
2019-1-19
Chevy3717
Flight distance : 1438566 ft
DJI Smart Controller  OcuSync 2.0  Operation Frequency Range 2.400-2.4835 GHz, 5.725-5.850 GHz[1]  Max Transmission Distance (unobstructed, free of interference) 2.400-2.4835 GHz: 8 km (FCC), 4 km (CE), 4 km (SRRC), 4 km (MIC) 5.725-5.850 GHz: 8 km (FCC), 2 km (CE), 5 km (SRRC)  Transmitter Power (EIRP) 2.400-2.4835 GHz: 25.5 dBm (FCC), 18.5 dBm (CE), 19 dBm (SRRC), 18.5 dBm (MIC) 5.725-5.850 GHz: 25.5 dBm (FCC), 12.5 dBm (CE), 18.5 dBm (SRRC)  Wi-Fi Protocol Wi-Fi Direct, Wireless Display, 802.11a/g/n/ac, Wi-Fi with 2×2 MIMO is supported  Operation Frequency Range 2.400-2.4835 GHz, 5.150-5.250 GHz 5.725-5.850 GHz  Transmitter Power (EIRP) 2.400-2.4835 GHz: 21.5 dBm (FCC), 18.5 dBm (CE) 18.5 dBm (SRRC), 20.5 dBm (MIC) 5.150-5.250 GHz: 19 dBm (FCC), 19 dBm (CE) 19 dBm (SRRC), 19 dBm (MIC) 5.725-5.850 GHz: 21 dBm (FCC), 13 dBm (CE), 21 dBm (SRRC)  Bluetooth Protocol Bluetooth 4.2  Operation Frequency Range 2.400-2.4835 GHz  Transmitter Power (EIRP) 4 dBm (FCC), 4 dBm (CE), 4 dBm (SRRC), 4 dBm (MIC)  Battery 18650 Li-ion (5000 mAh @ 7.2 V)  Charge Type Supports USB power adapters rated 12 V/2 A  Rated Power 15 W  Storage Capacity ROM 16 GB + scalable (microSD)  Charging Time 2 hours (using a USB power adapter rated 12 V/2 A)  Working Time 2.5 hours  Video Output Port HDMI Port  Power Supply Current / Voltage (USB-A port) 5 V/ 900 mA  Operation Temperature Range -4° to 104° F (-20° to 40° C)  Storage Temperature Range <1 month: -22° to 140° F (-30° to 60° C) 1-3 months: -22° to 113° F (-30° to 45° C) 3-6 months: -22° to 95° F (-30° to 35° C) >6 months: -22° to 77° F (-30° to 25° C)  Charging Temperature Range 41° to 104° F (5° to 40° C)  Supported Aircraft Models Mavic 2 Pro, Mavic 2 Zoom  GNSS GPS+GLONASS  Weight Approx. 630 g  Supported SD cards microSD™ Supports microSD cards with a capacity of up to 128 GB and R/W speed up to UHS-I Speed Grade 3
2019-1-21
mAIRs
I'm interested in the CPU, RAM and Chipset specs...
2019-1-21
Sweflyer
Flight distance : 14587497 ft
mAIRs Posted at 1-21 14:37
This is the one honey http://opensource.rock-chips.com/wiki_RK3288
https://forum.dji.com/forum.php? ... p;page=1#pid1630958
2019-1-23
mAIRs
Sweflyer Posted at 1-23 09:15
https://forum.dji.com/forum.php?mod=viewthread&tid=123131&page=1#pid1630958
Read the question again... chummer
2019-1-24
Sweflyer
mAIRs Posted at 1-24 04:43
Its the same as in the CS. What did you expect? dreamer..
2019-1-24
mAIRs
Sweflyer Posted at 1-24 04:56
Do you have actual proof that DJI re-hashed 4 year old (at least) tech once again?? a white paper or a hardware report from something like CPU-Z??? otherwise you're just dribbling garbage, perhaps trying to pretend like you know "so much" to impress people reading this forum??
If what your baseless texting is the case than what is DJI's excuse for not updating the CS to Android 7 and GO 4.3.10 like ON THE DJI CONTROLLER...
2019-1-24
mAIRs
I'd expect a bit more innovation from a $10 billion company.... perhaps... nah
2019-1-24
Sweflyer
mAIRs Posted at 1-24 05:07
no need for adroid 7 at all. You dont get it. What a pity.
2019-1-24
Sweflyer
mAIRs Posted at 1-24 05:08
Reuse is the key..
2019-1-24
mAIRs
Sweflyer Posted at 1-24 05:25
Didn't realize that you know me so well... you're amazing!
2019-1-24
mAIRs
Aye aye Captain
2019-1-24
Swedrone
https://forum.dji.com/thread-178246-1-1.html
2019-2-5
mAIRs
Swedrone Posted at 2-5 04:43
cheers.....
2019-2-5
Swedrone
Same to you !
2019-2-5
djiuser_Tuuz94kwu5xM
Flight distance : 1643907 ft
WOW, thank you for providing this URL...
It gives a glorious answer to this essential question.
I wish that someone wouldve posted the same type of answer on a similiar question regarding the CrystalSky Monitors! (there may be one but I havent found it.)
I think alot of folks are trying to compare the 2 device options, Smart RC & CrystalSky, and its hard to figure out without having them both in your hands.
2019-2-11
Thopter
mAIRs Posted at 2019-1-21 14:37
OriginalBo mentioned ’mediatek’ on a YT video.
2021-5-7
