Sparkz71
Flight distance : 24259 ft
May I ask what version of DJI Go 4 & the device (IOS/Android) you were using at the time? It makes a difference between versions of DJI Go 4 within my experience. Older versions work better for Spark & most devices with limited resources. Can you share the flight logs from the device or Spark?
If I try the latest version on DJI Go 4, I loose connection at random distances within 30 m , If I use the old version from 12 months ago, I can fly perfect LOS for 500 m above ground. After that I can't see Spark, but still have a good signal. I don't understand why it changes with new versions of DJI Go 4. Maybe the newer versions are too power hungry?
Good luck & best wishes... |
