Slow Support
1086 14 2019-2-5
kparrish18
Flight distance : 404232 ft
I have had a Fly-away case in for about a month now.  This is my second one which was due to a compass error and watching my beloved Spark fly away without the ability to control it.  Has anyone else had a similar experience recently?  This has been beyond frustrating.
2019-2-5
ssylca44
Flight distance : 434721 ft
You should provide more info about the flyaway.
2019-2-5
Warriewoodlad
Flight distance : 625230 ft
Mine was a  Care Refresh replacement which took almost 3 weeks, which is good for warranty work for that type of gear here.
2019-2-5
Lysak2003
Flight distance : 500052 ft
Ukraine
First of all sorry for your lose. I've created the poll on this issue: https://forum.dji.com/thread-176177-1-1.html?
You can share your experience in the comment section of the poll so other members of the Forum and DJI engineers could be aware.
2019-2-5
Lysak2003
Ukraine
Warriewoodlad Posted at 2-5 13:11
Excuse me, but when did it happen?
2019-2-5
DJI Diana
Flight distance : 2408 ft
Hi kparrish18. We're sorry for what happened with your DJI Spark. I know that is really frustrating to know to wait for the results. I managed to pull up the case, I will formally ask for assistance to get an update with this. Rest assured that this will be handled accordingly. Again, we apologize for the inconvenience. Appreciate your patience.
2019-2-5
kparrish18
ssylca44 Posted at 2-5 12:58
Here are the details of the flight:  Flying at about 300 ft above my house for about 9 minutes.  I did a Quick Shot and about 4 seconds after that I experienced a Yaw Error which was then followed by a Speed Error.  At this point I had lost the ability to control the Spark.  After that a series of Yaw Error messages then followed by a Compass Error. Exit P-GPS Mode; Yaw Error.  Then more Yaw Errors then this: IMU heading error. Please restart the aircraft.; Yaw Error. Then the slow drift began with more Yaw Errors. At  this point My altitude was still about 300 ft but the distance from home began to increase - slowly  from 60 ft to 100 ft. Still receiving Yaw Errors as the distance got greater and greater.  At 1184 ft i got this error: Command Timeout; Yaw Error.  Followed by more Yaw Errors then at 1256 ft this: Abnormal compass function or GPS signal detected. Aircraft switched to ATTI mode.; Yaw Error. Then more Yaw Errors then at 1343 ft  this: Command Timeout; Yaw Error.  More Yaw errors then at 2126 ft this: Downlink Restored (after 0m 2.5s); Yaw Error.  More Yaw Errors then finally this:Abnormal compass function or GPS signal detected. Aircraft switched to ATTI mode.; Yaw Error then this: Downlink Restored (after 0m 1.6s); Yaw Error to be followed by four more Yaw Errors and no contact after that.
2019-2-5
fans6f66f9da
I've had 2. one broken remote case, and one faulty battery case. Both very quick, I think the remote was returned in less than 2 weeks including shipping which was 3 days each way
2019-2-5
kparrish18
Lysak2003 Posted at 2-5 13:18
Excuse me, but when did it happen?[Image]
January 5, 2019
2019-2-5
Warriewoodlad
My Spark went for a swim August 2018. It was no fly away, it was pilot error. I accidentally pressed the land button instead of the RTH button. Unfortunately it was low over water at the time.
2019-2-6
Lysak2003
Ukraine
Warriewoodlad Posted at 2-6 00:52
Sounds pretty sad. I always try to move with huge precaution over water exactly because of posibility wrong jerky actions from myself.
2019-2-6
Sparkz71
Flight distance : 24259 ft
May I ask what version of DJI Go 4 &  the device (IOS/Android)  you were using at the time?   It makes a difference between versions of DJI Go 4 within my experience. Older versions work better for Spark & most devices with limited resources. Can you share the flight logs from the device or Spark?
If I try the latest version on DJI Go 4, I loose connection at random distances within 30 m , If I use the old version from 12 months ago, I can fly perfect LOS for 500 m above ground. After that I can't see Spark, but still have a good signal. I don't understand why it changes with new versions of DJI Go 4. Maybe the newer versions are too power hungry?
Good luck & best wishes...
2019-2-6
eYeSkYeYe
Croatia
How's the situation with sun flares in your area?
2019-2-6
kparrish18
DJI Diana Posted at 2-5 13:19
Thank you for your help! They contacted me today and said the Spark is covered under warranty and will be replaced.
2019-2-6
DJI Diana
kparrish18 Posted at 2-6 15:34
Hi there. That is good news! I hope I was able to help you in my own little way. Thank you for giving me the opportunity to help.
2019-2-6
