left dial doesn't tilt any more, but yaw
49927 15 2018-4-3
buscape
Flight distance : 686184 ft
Bulgaria
would you tell me what is hoing on with my drone? This is so weird. I can't tilt any more my gimbal. I can only move it left or right with the left wheel...
2018-4-3
buscape
Bulgaria
2018-4-3
DJI Elektra
buscape Posted at 2018-4-3 01:56
https://www.youtube.com/watch?v=9qUW6lGCabc
Hi, please try to calibrate your remote and see if it works. Please keep us updated, thanks.
2018-4-3
buscape
Bulgaria
DJI Elektra Posted at 2018-4-3 02:03
I've tried already - doesn't help.
2018-4-3
buscape
Bulgaria
Furthermore, I've downgraded it to 1.60 firmware, then upgraded it again to 1.9.3.
I relinked it again - doesn't help.
The only thing I didn't succeed to try was to downgrade it to 1.80 firmware version.
2018-4-3
DJI Elektra
buscape Posted at 2018-4-3 02:53
Did you try to long press the image screen and drag the circle to tilt the camera? Please contact our support and start a case: http://www.dji.com/support
2018-4-3
buscape
Bulgaria
DJI Elektra Posted at 2018-4-3 03:19
Long press tilting works fine!
2018-4-3
buscape
Bulgaria
Last time I've contacted your support it didn't help me at all. I will not send my RC to anywhere. DJI Germany support is a joke! They lost my time and money.
You can check my last issue - https://forum.dji.com/thread-71020-1-1.html
Still not resolved.
2018-4-3
buscape
Bulgaria
I've reset the remote using  C1, C2, and the record button - nothing's changed
I've reset to Factory Default using DJI Assistant - nothing's changed
2018-4-3
Thanks for keeping us updated. We're checking the exact status with our engineers and will come back later.
2018-4-3
buscape
Bulgaria
Using the remote control firmware 1.60 and the previous Aircraft firmware V02.00.0106 I can tilt the gimbal, but I have problem with the image and with the drone connection
2018-4-3
buscape
Bulgaria
Unfortunately I can't downgrade RC firmware to 1.80, only to the versions below 1.80.
2018-4-3
buscape Posted at 2018-4-3 05:48
Please first update the firmware to the latest version. Then try this method: power on the RC, press C1+C2+Shutter at the same time, don't let go of your fingers, power off the RC. Then you can normally power on the RC. See if it works.
2018-4-3
buscape
Bulgaria
DJI Thor Posted at 2018-4-3 23:59
It works, thank you. I thought I’ve already tried. But now I succeeded to follow exactly your instruction and it works. Thank you!
2018-4-4
buscape Posted at 2018-4-4 01:28
Thank you for your update, that's good to hear. Happy flying.
2018-4-4
EttoreCattoli
Flight distance : 2473432 ft
Many many thanks, I solved with your suggestion !!!
2019-3-10
