Charging Hub shows red light while plugging in the battery
5420 4 2019-4-14
TGWFJ
Flight distance : 1217 ft
United Arab Emirates
I had tried to charge up one of my mavic air battery and it never got charged. Red light appeared on the charging hub as well as when I click the button on the battery, no light shows up. I had used the battery 2 weeks before for the Mavic air. What to do ?
2019-4-14
AlansDronePics
Flight distance : 823163 ft
Guernsey
What % did you run it down to while flying?
2019-4-14
TGWFJ
AlansDronePics Posted at 4-14 22:05
I had set warning at 30%, when the notification popped up, I landed it in the next 30 seconds.
I had contacted DJI regarding this issue and they didnt even care to consider the defect of their product. When I mentioned that their product did not last even a single year, they had told me that the battery only works for a limited cycles and goes dead after. In the end their only possible solution is to buy a new battery.
I live in UAE and the temprature does not drop much here for the battery to die. And this happened 3 weeks after my last use.
2019-4-19
TGWFJ
30%. I had set a warning at 30%, landed in the next 30 seconds.
2019-4-19
A J
Flight distance : 14588274 ft
TGWFJ Posted at 4-19 21:45
Either the hub is bust or the battery - I'm guessing you have more than one battery to have a hub - so do the other batteries cause it to turn red?
2019-4-20
