Cannot Connect Go Share to My iPhone X
11535 24 2019-4-26
pnelson3
Flight distance : 1098369 ft
I have tried numerous times to connect my Smart Controller to my iPhone X using Go Share so I can transfer images. When attempting to make the initial connection by reading the QR code on the SC, I consistently get the following "Connection Failed" warning in DJI Go 4 on my iPhone w/ instructions that are not helpful (looks like a coding error). I have tried restarting everything. I reloaded DJI Go 4 on my iPhone, checked to make sure that I can get a solid network connection from my SC (I can), and when trying to connect manually through Go Share, no WiFi service from the SC comes up in the iPhone's list of networks, so I can't even make the connection manually.
Has anyone else had this problem and know of a solution?
2019-4-26
pnelson3
Sorry for the huge picture - my first post here - I'll know better next time
2019-4-26
Dronie2
Flight distance : 1336365 ft
Is Bluetooth connected?
2019-4-30
yaron elram
Flight distance : 29035 ft
Israel
I have this problem also with a phone samsung galaxy 8
Someone has a solution ?
2019-5-2
wheeler
Flight distance : 422799 ft
Mine was connecting fine. But came to do some transfers today and it will not connect ? Deleted an reinstalled the Go4 app and factory reset the smart controller still won’t connect. Strange how it was fine two days ago ?
2019-5-5
wheeler
Been trying everything over the last couple of days to get Go share to connect to my IPhone x. I tried manual connection, two different iPhones an Android phone nothing. Then thought I’m going through this Smart controller section at a time slowly. I’m going through the menu for manual tethering noticed at the bottom 5Ghz clicked on that get an option of 2.4Ghz an 5Ghz changed it to 2.4Ghz and Sh1t a brick it works !!!
2019-5-7
yaron elram
Israel
Allow an accurate explanation that after changing the settings in me still does not work.  Explain where to enter and what to change
2019-5-10
wheeler
yaron elram Posted at 5-10 13:45
Settings, More...., Go Share, Set Go Share Hotspot, scroll down to select AP Band choose 2.4GHz band or 5GHz band. Hope that helps
2019-5-12
Dronie2
Thanks for the info, just in case...
2019-5-18
Efrommel13
Flight distance : 73606 ft
Puerto Rico
Can connect using the QR code, im using a s10 and nothing, the iPhone Xr worked. but not the s10, and i have used it before. is very odd.
2019-6-18
djiuser_0wBf9d03io6w
Portugal
I got the same problem!! Can’t use go share between my smart controller and iPhone! Help!!
2019-8-22
fans701be579
wheeler Posted at 5-12 06:52
thank you that worked was a big help
2019-10-12
fans701be579
fans701be579 Posted at 10-12 13:12
well it worked for an hour now back to square one its asking scan QR code which i do then get "connection failed"
2019-10-12
djiuser_pJKT1wqiSCon
Resetting your network settings worked for me
2019-12-1
Techsofter_Irl
wheeler Posted at 2019-5-7 15:46
Changing the setting to 2.4Ghz AP band sorted me out here too. Huawei Mate 20 Pro & SC even though the 20 pro supports 5ghz wifi.
2020-1-19
AnthonyLauter
Flight distance : 74180 ft
You are an absolute genius. Thank you.
2020-2-2
AnthonyLauter
wheeler Posted at 2019-5-12 06:52
2020-2-2
fansfed0fe28
Genius! After pulling hair out for 3 days, this worked. Thank you.
2020-8-31
DaMa
Flight distance : 889662 ft
fansfed0fe28 Posted at 8-31 16:01
I'll soon have nothing more to pull out ... I can't get it. Wireless with GO4 via QR no chance, but no problems with the iPhone camera. BT connection also problem-free. The image transfer with GoShare to an iPhone 8 - doesn't work !? No problem with a cable to the iMac. I give up ... and use the cable.
2020-10-7
djiuser_Sl35FZt4QVcw
You. Are. A. Saint!
2020-10-31
djiuser_fwfS3C8dwsXA
Have you resolved issues??? I am trying to connect to an iPhone...... it is doing my head in
2020-11-29
NickdotG
Check the setting in the Go-share app on your phone. Make sure it’s set to allow for the local network to be used
That fixed my problem
2020-12-12
djiuser_P1Q1m8kgFr3I
I was having the same problem connecting SC to iPhone 12 and this changing frequency tip solved the issue straight away. Many thanks Wheeler.
2021-2-10
MaxS
Flight distance : 158720 ft
Finland
I have the same issue , iPhone 11 Pro and latest firmware on SC and iPhone
2021-7-17
DaMa
I had the same problem with my iPhon 8. Maybe this will work (#7) https://forum.dji.com/forum.php?mod=viewthread&tid=242194
2021-7-17
