El Diabolico
DaMa Posted at 5-14 05:56
If you get a sharp picture with the Cytronix case shown above and the Osmo Pocket, you're my hero! And yes, you have also correctly recognized "... WHEN designed properly ..." How do you get the Osmo Pocket in such a housing, as you have shown? You're shooting sparrows with cannons... Everything correct what you have written, only the forum ... I'm looking forward to the DJI case, also because it has a "straight view" ...
Don't distort what I said, I am replying to your silly comment on domes creating blurry images not the fact that the Cytronix case is rubbish... at no point you mentioned specifically the Cytronix case. Don't play with our perception. Check the UW case for the Insta 360, it is very similar to the Cytronix so a domed case works.
I am quoting you:
'No, the DJI engineers would not do such a stupid thing. A round dome in front of the lens generates under water - with air in between - a blurred image. (WRONG as described in my previous comment). Refractive index ... a curved surface leads to the offset of the focal point on the chip' (Lol Obviously you made this up because it sounds cool but WRONG again).'
DJI has opted for a flat cover because probably the FoV on the OP doesn't create any vignetting effect. We might see from 3d party manufacturers go for a domed solution, it is irrelevant.
I would suggest you leave it here not to further expose your 'expert' approach.
