Osmo Action’s Wi-Fi gets disconnected automatically?
113917 48 2019-5-22
Osmo Action’s Wi-Fi gets disconnected automatically? Let me show you how to fix it!
After the Osmo Action is released, we noticed that when users connect an Android device to Osmo Action’s Wi-Fi, it often gets disconnected automatically.
After testing, we learned that this issue is caused by the Android device’s network auto-switch function, a function that is also known as WLAN+, which is exclusively available to Android system. So how does the function cause auto-disconnection?
After the Android mobile device is connected to Wi-Fi, if the mobile device finds that the Wi-Fi is not working, the device will automatically switch to another available Wi-Fi that has been connected before or to a 4G network, causing Osmo Action’s Wi-Fi disconnection. Some mobile devices would notify the user of the change, but others don’t.
To ensure that Osmo Action can be connected to the mobile device and work normally, it is recommended to turn off this function.
It should be noted that the Wi-Fi auto-switch function’s name varies with different manufacturers. You can check the chart below to learn how to enable and disable the function in different mobile devices.
If you encounter similar questions, please try the method mentioned above. Please contact DJI Support if you have any questions.
Thank you for your support.
2019-5-22
Estelle Lau
Flight distance : 38632 ft
It is very nicely done, great post, thank you for informing us this, however, I have no Osmo Action,
2019-5-22
IftiBashir
Also note that when the Action goes into standby, the WiFi also loses connection.
It has no Bluetooth like GoPro. With GoPro, when the camera goes into standby the WiFi goes to 'sleep' to save power but low power Bluetooth stays active. When a connection is initiated by the app, the bluetooth connection is established first, then the WiFi is woken and established.  Great system by GoPro.
With the Action, this is not possible. So best to set a longer time before standby kicks in on the camera.
2019-5-22
A J
Flight distance : 14754314 ft
Excellent info
2019-5-24
Thanks for the info!
2019-5-24
TheCameraGuy
Flight distance : 40866 ft
Mindy, thanks for the help, however it is as much of a problem with iOS as it is with Android. I could not keep the phone (iPhone X) and the Osmo Action connected long enough to do the upgrade. I ended up doing the upgrade by down loading the file to a memory card and installing the memory card into the camera, which worked well.
2019-5-24
covfefe
I can't get it to connect to my Oneplus 6t for more than 1 second.  I have WiFi auto switching off. It connects to my old Pixel 2XL fine and iPhones X as well. Please advise.
2019-5-26
ff22
covfefe Posted at 5-26 08:16
I really like your user name.  But do you have permission to use it? (g)
2019-5-26
Maxkim
South Korea
Good ! Thank you for the good information
2019-5-27
wisniak
Flight distance : 270528 ft
Israel
Good info but not really applicable while at home, if you have several networks (sat 2.54GHZ and 5GHZ), not to mention Access Points etc, and you want the phone/tablet to freely roam among them.
2019-5-28
peiter
This disconnecting on its own do not happen on my years old phone with android 7.1.1
My phone i assume have pretty default settings, all i do with phones are remove 2 apps for every 1 i install, and then make or receive phone calls and TXT messages.
Do not use wifi at home, don't use other wifi, only use wifi in phone to gadget situations and even that i try my best to limit.
2019-5-29
Hi covfefe, please make sure other Bluetooth has been turned off when connecting to Oneplus 6T, connect to Osmo Action's Bluetooth first and then enter the APP to connect its wifi. Please set the wifi settings to Auto in Osmo Action to see if the issue persists.
2019-5-31
TheCameraGuy Posted at 5-24 05:04
Hi TheCameraGuy, sorry to know the issue also happens in iOS, may I verify after the firmware updated successfully, do you still have the connection problems?
2019-5-31
TheCameraGuy
DJI Mindy Posted at 5-31 03:01
Yes I am on the most recent firmware and it still happens to me.
2019-5-31
Toedles
Flight distance : 7676339 ft
Works well with my iPhone XS, no dramas, touch wood...
2019-6-1
CRAIGMART75
Flight distance : 1543901 ft
Thanks for the info !!!!
2019-6-2
alanchai
Brunei
Is there a way to Turn off the WIFI / Bluetooth when not in use?  In order to save some battery juice ?
2019-6-9
Gboing
alanchai Posted at 6-9 05:46
I second this.
Would be nice to be able to manually turn off wifi/bluetooth.
2019-6-9
Hi alanchai, the Wifi cannot be turned off in Osmo Action, we will transfer your suggestion to our engineers for consideration, thank you.
2019-6-13
Gboing Posted at 6-9 18:15
I second this.
Hi Gboing, this feedback has been transferred to our engineers, appreciate your support to DJI.
2019-6-13
TheCameraGuy Posted at 5-31 05:57
Sorry for the late response, hope the issue has been solved, if not, please try to reset the wifi settings in the Settings of Osmo Action to see if it helps.
2019-6-13
Gboing
DJI Mindy Posted at 6-13 00:21
Thank you, Mindy.
2019-6-13
TheCameraGuy
DJI Mindy Posted at 6-13 00:22
Thanks very much. I’ll give it a try
2019-6-13
TheCameraGuy Posted at 6-13 18:25
You are welcome, please keep me updated with the result.
2019-6-13
Gboing Posted at 6-13 05:45
Thank you, Mindy.
I have verified with our engineers, the wifi of Osmo Action will be turned off automatically when no mobile device is connected in one minute to save the battery power.
2019-6-13
Jimmy Singh
For Google Pixel, you have to turn off Mobile Data prior to connecting with Mimo App. Android actively turns off WiFi if there is no active data on that ssid and will disconnect you. Also set to 2.4ghz
2019-6-22
SidneyW
Osmo Action error message "unofficial battery detected" showing in camera screen.  Why do I get this error message?  The battery is fully charged, yet in Mimo it says less than 10%.
2019-6-23
ff22
SidneyW Posted at 6-23 07:02
Some things to try to see if it gets back to normal.  Remove the battery and leave it out for a while.  Replace it.  I'm not sure if it has a "reboot" option but you can try pressing and HOLDING the power button.
Maybe you can try using the Settings to RESET the device.
You might want to start a new thread with that Battery message as its subject to grab more attention.
2019-6-23
SidneyW
i have tried reset and the reboot... will take the battery out overnight and see what will happen next.  Already emailed my DJI contact at HQ.  I have not seen this error message before.
2019-6-23
SidneyW Posted at 6-23 16:47
Hi SidneyW, I have replied your own thread, please keep me updated there, thank you.
2019-6-23
Flight distance : 11959747 ft
Hi dji Mindy, I have had to send back my Osmo Action because of problems, it has reached repair centre since Monday evening, but I have heard nothing yet.
I wonder can you chase it up for me, was hoping to have it back for 05/07 to take on vacation. My case number is below, I somehow have two case numbers I will leave both because I’m not sure which one is right, would appreciate any help you can give me on this.
3166560-Q9Z6Q7
3177417-T7D0P0
2019-6-27
hallmark007 Posted at 6-27 01:34
Hi hallmark007, I've canceled CAS-3177417-T7D0P0 because it is duplicated with CAS-3166560-Q9Z6Q7.
Sorry to know the package still hasn't been checked-in. We will inform the local repair center to double check and expedite the progress, please note the email notification later, thank you.
2019-6-28
Woe
Flight distance : 4129268 ft
Thanks for the info.
2019-7-1
DJI Mindy Posted at 6-28 00:18
Hi Dji Mindy, thank you very much for all your help, my OA is now on its way back to me all fixed and ready to go .
2019-7-3
hallmark007 Posted at 7-3 03:31
Glad to know that, hope you will receive it soon.
2019-7-4
KArol Levy
Bonjour à tous,  Je me permets de vous poser une question concernant notre DJI Osmo 2   Nous avons un petit problème voici le message sur l'iphone 8 IOS 14.4 " Allumez le bluetooth du smartphone et revenez sur l'application " La dji Osmo fonctionne mais pas l'appli DJI GO ?  Merci pour votre aide .  Cordialement   K
2021-2-6
Roman Butler
Thank you, the post is so great.
2021-4-13
djiuser_hoCwOtWOsID6
My new DJI Osmo Action camera was disconnecting frequently from DJI Mimo on my iPhone 10, which is running iOS 14.6. I updated the firmware when I unboxed the camera and it has the latest firmware. Originally I set the camera's wifi connection to auto but it still disconnected randomly and the Mimo app would intermittently refuse to connect or connect for a short time and then disconnect. Then I set the camera's wifi setting to 2.4 GHz and reset the wifi connection. It now seems to be working since the camera's view streams correctly to my iPhone's Mimo app and I can start and stop the video recording from Mimo. I couldn't find anything in the user manual that mentioned this problem. Is it a known bug in either the Mimo app or the camera's firmware?
2021-6-12
ameranda
The DJI Mimo app on my iPhone 12 (iOS 14.7.1) automatically disconnects from my DJI Osmo Action camera when I switch to another app on the iPhone even when the Mimo app is still running in the background. Normally, that wouldn't be a huge problem except that the camera is mounted under the wing of my airplane and there's no way to restart the camera in flight when this happens. I have an Appareo Stratus 2i ADS-B In receiver installed in my airplane and it is the only other wifi connection available in the airplane while in flight. I have connected to it before with my iPhone so maybe what is happening is that when the Mimo app is not in the foreground, then it releases the wifi connection and my iPhone switches to the Stratus. However, I've tried switching back to the Mimo app and reconnecting to the Osmo Action's wifi. That doesn't work. From what I've read, it is normal behavior for the Mimo app to disconnect from the Osmo Action when it is not running in the foreground. Has any thought been given to changing the Mimo app to maintain the Osmo Action wifi connection when running in the background?
2021-8-1
Fishycomics
All I did here was show, have to yap Lol app disconnects within Xamount of seconds,
2021-8-1
