S-e-ven
Flight distance : 5922034 ft
Thanks for the hint.
I just think that this "not taking in account" is the reason, that the Go4 uses in general just under 2/3 of the max speed in Sport (DJI Spark at least) for an RTH:
In case the Wind is high, still 36 kph should be possible, mostly is.
I have had not many flights, where fling direct in the wind was less then 36kph, in Sport.
And IF it slows really down, it is often enough to take the nose a bit out of the wind.
Some degrees more left or more right gets you often almost full speed, again.
And later coming back from there is also "wind from the side.
Perhaps the video is cranking, but the bird is at the Homeoint. Or close by.
I have experience in such situations.
I cancel most battery RTH, finish what I am on, fly it back in Sport then and...., s..t, that is maybe not quick enough, change the course a bit, ok, better ! ;-) |
