Osmo Pocket - more robust than you might think
3493 14 2019-7-23
Fat Controller
Flight distance : 155246 ft
I went for a hike today along the North Antrim coast from Dunseverick to The Giant's Causeway. Just as I was removing the Osmo Pocket from its case a large horsefly sunk its jaws into my hand. I felft the nip and swatted it off, causing the Osmo to fly out of the case and drop hard onto the rough stone path. I thought 'here we go, I've broken it' but no, it was fine. There are a couple of scratches on the body of the camera and the gimbal but no major damage, good news the lens is OK. I have checked the footage and it's fine, I'll post it when I've had a chance to edit it. For now, you can view the route on Wikiloc here.
2019-7-23
Flight distance : 10186312 ft
Dropped mine on it’s head on concrete in Spain, one small dent but everything working fine, it’s not as delicate as we might think .
2019-7-23
thortschman
I lost mine while skiing in the snow. Found it seconds later full of snow. Recording was still running and works perfectly.
2019-7-23
Tactical Trvlr
Flight distance : 255407 ft
I have also found my OP to be very durable. I have used it while running around New York City and spent a lot of time at Disney theme parks. I’m not super careful and it’s held up very well. I’ve even used it in some light rain with no issues.
2019-7-23
Curt1591
Osmo Pocket Crash Test
2019-7-23
Bing Err
Flight distance : 9249964 ft
I've dropped mine on asphalt and cement and few times and it's fine. Lots of scratches but works perfectly.
2019-7-23
Punchbuggy
Flight distance : 573054 ft
If you should drop your Pocket, check subsequent recordings carefully to make sure the sensor is how it should be.
I inadvertently dropped mine after only a couple of weeks use, and thereafter there was a soft focus issue on the right 1/3 of the image (the rest of the image was perfectly in focus). I provided examples to my local camera dealer (who I bought the Pocket from), it was sent away for inspection, and a brand new one was returned. Image was perfect again - phew!
2019-7-23
David Martin Graff
Nicely done - thanks again for sharing!
2019-7-23
Mars5150
Flight distance : 391493 ft
Goog to know! But I will not test it...
2019-7-24
Neo Supreme
Flight distance : 76329 ft
Great, so now I can record whilst in a mosh pit without anxiety
2019-7-24
Fat Controller
I've already tested mine once, don't plan on doing it again, but the video Curt1591 posted shows it's even more solid than I thought it was
2019-7-24
Fat Controller
Neo Supreme Posted at 7-24 05:57
I'm thinking that if I get mugged I'll be able to bash my assailant over the head with it.
2019-7-24
Vjah
I dropped mine on tiles several times now but it doesn't even have a scratch and everything works perfectly I was very surprised
2019-7-25
LookAt_Wictim
Flight distance : 2621982 ft
Slovakia
My osmo pocket dropped today on the ground from 2 meters straight on gimbal head. After closer look everthing seems ok stabilization works and camera is ok.
2019-7-25
Fat Controller
LookAt_Wictim Posted at 7-25 09:51
The damage to mine was similar. It just  helps to give a well-used look to your equipment.
2019-7-26
