Setting controller homepoint
4745 11 2019-8-29
djiuser_C3VEhn7USYWs
I'm looking for a  solution or explanation of my issues with weak or missing GPS signal home point recognition issue. I'm on all of the latest releases on the Mavic 2 controller and on my IOS device. IOS Location services are "always on" for DJI GO 4 app. My compasses in the Mavic and my phone are calibrated (multiple times). My "find my iPhone" app knows which corner of my living room I'm in. Today with the controller switch selected in "Tripod Mode" I was able to get my controller recognized as the home point,... I thought. Even though the switch was in Tripod mode, the Mavic was operating in Position/GPS mode. When I executed a return to home, it wasn't the location of my controller. The return to home location was where the take-off location was, which I had walked about 50 ft away from. Toggling the mode switch between the 3 different mode positions cleared up the non-selected mode.,...But this happened twice. I couldn't get the controller set as home point again, (even the false result). I'm brand new to all of this. Is there a setting or option I should set to make this work properly? I think I've read about, and seen every video on the Mavic 2 operation but my brain is on data overload. I could have missed something. Thanks in advance for any help.
2019-8-29
The home point will always be the take off location unless you later update it by swiping across the screen and selecting a new home point.  This video will show it better -
2019-8-29
jmb63
Flight distance : 7009439 ft
What device (phone/tablet) are you using? I ask because some of the tablets do not have a built-in GPS chip (WIFI only ipad mini for example)and the device needs GPS ( the drone has it's own GPS so that is how it gets home) to now where it is to update the home point
2019-8-29
Kevin in Reily
jmb63 Posted at 8-29 06:02
I'm using an iPhone XS.  I've tried setting the controller home point two ways. the way described above in the video and also by tapping the drone icon on the main screen which takes you to the same homepoint setting option.  In both cases the message I get is "GPS signal too weak from device".  I believe this is a known issue with "some" IOS devices.  However using the find iPhone app, my location is displayed very accurately.
2019-8-29
Kevin in Reily
Kevin in Reily Posted at 8-29 07:05
Apparently there isn't an easy solution for this problem since DJI hasn't responded here and others have the same issue on another forum. Had I known about this, i would have chosen a unit with a smart controller. I still have time to execute a return and will with not so favorable feedback.
2019-8-30
HH1
Flight distance : 73114 ft
DAFlys , thanks for that video, it explains some things I have been wondering about.
2019-8-31
HH1 Posted at 8-31 13:22
you're very welcome.
2019-9-2
kovat53
Flight distance : 324521 ft
Hungary
DAFlys Posted at 8-29 04:36
thanks for sharing, some of them were hidden at least for me....
2019-9-2
kovat53 Posted at 9-2 02:44
Tried it, but some of them, i.e. first doesn't work for me. I use a Huawei Mediapad M3 Lite/Android, and if I try the first suggested method, Google Assistant comes up. Are some of the functions only for iOS?
Not sure,  I didnt create the video just shared a link to help out.
2019-9-2
kovat53
Hungary
DAFlys Posted at 9-2 04:31
Anyway thank you very much
2019-9-2
Drone34
Flight distance : 84091 ft
There are a number of us here who have expressed some frustration with this.  It would be nice for DJI to respond to the issue and fix the software, or to at least acknowledge a fix is needed.
2019-9-3
