Bypassing obstacles when Return To Home (RTH)
746 15 2019-9-10
AngelCaido
Flight distance : 417073 ft
Driving the Mavic 2 Zoom drone to go around some mountains, it loses the signal and begins to return home.
Turn in the direction of the takeoff point, then go up to the 50 meters you had configured to do the rth, but on the way you will find rocks that you have to overcome.
2019-9-10
Hello and good day AngelCaido. Thank you for sharing these information and this incredible video you have captured. Have a safe and a happy flying always.
2019-9-10
If mavic looses signal initiating RTH it will first retrace the last 60 seconds of its outward flight if it reconnects it will wait 10 seconds if no reconnection is made or controller fails to take over it will go to Rth height and return home using OA to avoid obstacles. There are only two occasions this won’t happen , inside 50m or outside 2000m.
You video seems to show a situation whereby RTH was initiated by the controller, and is a good example . Thanks for posting .
2019-9-10
Ex Machina
Flight distance : 1806362 ft
hallmark007 Posted at 9-10 10:07
Huh, so when you have signal failure 2000m or more from the home point -- what happens if RTH is not an option at that distance?
2019-9-10
Ex Machina
Nicely done demo.
2019-9-10
Ex Machina Posted at 9-10 10:43
If you lose signal at further than 2000m craft goes to Rth height and flies straight home.
2019-9-10
2019-9-10
Matthew Dobrski
Flight distance : 1831050 ft
Huh, excellent demonstration of this amazing safety feature at it's best! Bravo ... and congrats on happy outcome
2019-9-10
Ex Machina
hallmark007 Posted at 9-10 10:46
Ah, it skips the retrace your route step and flies straight home, gotcha. Wonder why?
2019-9-10
Ex Machina Posted at 9-10 12:08
Would think it’s to preserve battery flying out over 2000m will always mean good chunk of battery used so if you add 60 seconds potentially flying further away maybe danger of using up much needed battery time, I’m speculating here but with some common sense .
2019-9-10
Ex Machina
hallmark007 Posted at 9-10 12:20
I guess? A voltage check could inform that decision tree and is already used in other failsafe computations, isn't it? But that does seem a likely answer -- 60 secs is a long time at the edge of the performance envelope.
2019-9-10
Woe
Flight distance : 4129268 ft
Very nice demo. Thanks for sharing
2019-9-10
A J
Flight distance : 14588274 ft
Excellent demo
2019-9-11
James 0522
Flight distance : 191493 ft
very interesting. Thanks for sharing your video.
2019-9-11
Super demo,  thanks for making this.
2019-9-11
JJB*
Flight distance : 12566335 ft
Interesting video it is.
At detecting an obstacle, a M2Z stops and ascends until no obstacle is sensed.
in the video at the first stop craft descends just a little and start again to fly forward.
At the second sensed obstacle it did ascends, than fwd flying.
Why not acsends at the first stop?
cheers
JJB
2019-9-11
