There are lots of early threads on this topic on the forum and although the audio adapter is TRS and requires a wired mic connected as stereo, meaning there must be a live feed to the tip and ring with the return to the sleeve, the output is neither mono nor true stereo. DJI will only reply that it is two-channel. If you want true stereo you are better off using an external recorder.
Hi, thank you for reaching out and for the inquiry. The output will depend on the microphone you will be using on the 3.5mm mic adapter. If the external microphone is mono recorded, then the recorded or output audio is mono. And if the external microphone is a two-channel stereo mic, then the recorded or output audio will be a two-channel stereo. Thank you for your support.
DJI Tony Posted at 9-8 11:57
Thanks for the response. I am thinking of using a Zoom H2 so the signal would be stereo.
Ray-CubeAce Posted at 9-8 08:59
Thanks for the response. I plan on using a Zoom H2 so I can get a recording of sound source on that, and also a recording a passed through to the Osmo Pocket. Having stereo direct on the Osmo Pocket will reduce the amount of post processing work needed.
TheCameraLens Posted at 9-9 04:46
I understand. The internal mics give a sort of stereo in the right conditions but the separation of channels using the audio adapter is almost non-existant if at all in my opinion. Try comparing the two recordings side by side and tell me what you think. If nothing else your setup would allow easier syncing if needed.
Actually, the reply you get from DJI Tony is the first time I've seen a Mod here use the term Stereo.
Ray-CubeAce Posted at 9-9 07:29
I will probably get an adapter in the next month or two. I will let you know what results I get.
Are you sure ??? I have been tested a stereo microphone on OP and did't found any difference.OP got two mono channels !!! And you can't to record stereo on it !!!
Sauliuslag Posted at 9-11 05:56
Hi, thanks for the prompt reply. The Osmo Pocket is recorded in stereo but the dual channel cannot be separated. Hope that this would clarify your query. Thank you for understanding.
DJI Tony Posted at 9-12 14:30
Hi DJI Tony.
It sounds like you are saying that left and right channels are being recorded to channel one the then recorded again on channel two. That effectively both channels contain both the left and the right information and that information cannot be reconstituted into its component parts. Is that correct?
Ray-CubeAce Posted at 9-12 23:14
Hi DJI Tony.
If that’s the case then someone was having a bad day when they came up with that idea, still I guess stereo is a bit new to expect everyone to get their heads around!
djiuser_SGtX4I7iJci7 Posted at 9-13 01:44
It's complicated.
There is some indication that the Osmo Pocket itself can record stereo with its inboard mics but the mics are placed at 90 degrees to each other in the vertical plane and again in the horizontal so it doesn't pick up what your ears hear no matter what you do with it and can't as far as I'm aware can't be rectified with editing although in odd circumstances I have heard what could be almost stereo when I've recorded with people below me and to my right. There is some definite separation of the two signals at that point.
The adapter on the other hand as far as I can find out is using a Texas Instruments Burrs Brown four-channel ADC that can be configured several ways. What I don't know is if that is a hard-wired configuration or not or how it has been implemented. If it is hard wired and is indeed the chip I think is being used it may explain why there have been no new adapters on the market for a while if DJI are either changing the chip used or trying to figure out how to get the audio sorted by a rewire.
This is all speculation on my part with no hard evidence to back it up but I do wonder.
What I do know is the audio I'm getting on my Osmo Pocket via my audio adapter is not my idea of a normal stereo image.
