longieb
Hi
I flew my p3a on Wednesday without issue twice, no crash no issues and wonderful footage.
On Thursday I started it up as normal. I use an I Pad mini 3. As all ways I started up the app, then the RC then the aircraft. everything appeared fine and video feed appeared on the screen and I was able to move the gimbal, however no other aspects of the aircraft were visible. I was not able to see the battery status, the satellites and when you go in to the setting for the aircraft everything was back to default and not able to be changed. Having this issues I decided to pack it away for the night in an effort not to make matters worse.
On Friday, I unpacked it and again the same, no aircraft display on the I Pad apart from the camera. During the time that it was on, the rear lights would wither be a yellow or a green, it appears to change each time I turn it on. The aircraft also beeps DD DD DD DD then after a while DDDDDDDDDDDDDD then to a solid tone. I let it run fro 25 min and tried again, however no difference.
I tried uninstalling the DJI go app and re installing it. I tried re doing the firmware update for both the Aircraft and the RC, however the aircraft does the same as above and the RC's LED light just stays red and only beeps once it has been inactive for some time. Upon putting the SD card back in the computer it stated for the aircraft that it was a success along with stating abort it is the same or older firmware. Upon doing it with the controller, there is no text file, indicating that it has not attempted the update.
I use the SD card in a USB card reader way of updating, however I have tried connecting to the gimbal and then to the controller, but like the above the drone beeping, indicating that it has the current firmware but there is nothing for the RC.
I read there is a way to update it through the app, however going into the status menu, the RC states that its status is fine.
Please help.
Nothing more frustrating then having it and not being able to fly it.
Thanks in advanced.
