Windows (7 and 10) does not recognize P4 Pro
1248 9 2020-1-8
ALDOT-Steve
I have tried this with 3 P4 drones and 5 different computers all running DJI Assistant 2 for Phantom. 4 were running Windows and one was pulled from mothballs running 7. I have tried both the current version of assistant and the previous. The issue isn't with version number of either the OS or the software. It seems that none of my computers even recognize that the drones are plugged into the USB port (yes I have tried 7 or 8 different cables). Windows device manager does not register a new device plugged in. All three drones have freshly formatted sd cards installed. I am able to connect them to the controller and tablet and fly with no issues beyond getting an alert to calibrate on one drone. I have uninstalled and reinstalled the USB drivers and even tried this on a computer that has never has never been used for anything with a fresh Windows install. I do not have a Mac available to use.
I welcome any and all assistance.
Steve
2020-1-8
ALDOT-Steve
2020-1-8
JPilotR
Flight distance : 584662 ft
You are going to need to download the DJI Assistant for P4P app. I think you can download it from the support pages on the DJI site. Once you download it, you may need to be in Windows Admin mode to successfully run the application -- sometimes though it runs fine in "normal" Windows mode (not in Admin mode). It can be a crap-shoot. Good luck!
2020-1-8
ALDOT-Steve
JPilotR Posted at 1-8 09:11
I have that already. Upgraded to v 2.0.8 on my computer and still nothing. The issue is not the DJI application. I am a network and system admin.
2020-1-8
Mark The Droner
Flight distance : 2917 ft
Try this:   https://driverfinderpro.com/driv ... ment-in-windows-10/
Good luck
2020-1-8
ALDOT-Steve
Mark The Droner Posted at 1-8 09:24
Try this:   https://driverfinderpro.com/driver-guide/how-to-disable-driver-signature-enforcement-in-windows-10/
Good luck
Nope on that one as well. Thanks.
2020-1-8
mattj47
did you try the F7 on boot up and select the disable driver signature enforcement I did this on my win 7 as I was having trouble using the dji assistant 2 to calibrate the sensors after a prompt from the app.
2020-1-27
PowerBand1
Borrow a Mac its a whole lot easier.
2020-1-30
PowerBand1 Posted at 1-30 11:05
What for? To hit the drone with? I agree, that's about all a Mac is good for.
2020-1-30
ALDOT-Steve
Finally found the answer to this one: All of the USB cables had been replaced at some point with android USB 1.1 cables. When I used a USB 2.0 cable, everything worked correctly.
2021-6-10
