Remote controll update
1211 11 2015-8-7
soelv-si
I have trouble with updating my remote controller. I have both tried via the bird gimbal and on USB stick. When turning on the blue light showing an update does not appear at all. Can anyone help?
As long as the remote controller is not updated, the camera view in the DJI GO App wil not function.
2015-8-7
sploodge
Flight distance : 809350 ft
can you post the TXT LOG files from the attempted firmware update ( should be on the SD card you use to update the controller )
2015-8-7
soelv-si
There is no txt log file. The remote controller is not responding to neither USB stick or when i plug in the gimbal.
2015-8-7
soelv-si
There is absolutely no reaction from the remote controller when I plug in a USB stick or the cable between the bird and the controller. Anyone experiencing the same issue? I have also tried older versions of the firmware update.
2015-8-7
liner911
Same issue here and i have been trying for days to get answers / calls / chat support for resolution......NO RESPONSE ..... NO HELP
2015-8-7
soelv-si
Thanks anyway, hope there will be a solution soon.
2015-8-7
hundleton1
Flight distance : 2741657 ft
Please post the model number off the back of the controller, what device you are using ?
Is DJI Go telling you there is an update available ?
2015-8-7
soelv-si
Model: GL300A. The DJI Go does not function, i only get access to forum etc, it will not connect to the bird or the remote controller. I have the latest app version on my Iphone 6.
2015-8-7
Kookaburra
Hey Im having a simmilar problem - the remote does communicate with the drone but I cant seem to update the firmware - thus i get no text read out. I try doing it with usb adaper and micro sd card, I try connecting direct to Ithe bird and nothign happens - maybe its already updated and I need to wait for the app to ask me to update it, I think somewher i read once you update it via app thats the only way you will update - but ive recieved no prompts althoug the app has asked for the aircraft to be updated,which i have done successfully.
Any advice appreciated - Hundleton 1 would you be interested in my model number? this buy is only 3 weeks old.
Cheers,
2015-9-2
Sling Shot
Reinstall the GO APP application...see if this helps...
2015-9-2
SpunOne69
I had this issue with DJI GO version 2.0, once they updated to 2.0.2 it just stopped saying the firmware was out of date.  Check the version you are running...
2015-9-2
iceman58
Flight distance : 9016 ft
Try updating your controller through the app, start the app and turn on the controller and see if you  get a controller update and hit the download update, make sure the cable is hooked to your tablet and the controller
2015-9-2
